adjustable sleeve coilovers?
hey guys i have a tight budget and im looking at the skunk2 adjustable sleeve coilovers for my 99 TL!
do you think the ride will be okay with the original struts?
if not how can i compisate this?
coilovers should come with new shocks/struts
otherwise you are just buying a set of coil springs,,shorter than stock
stock 99 shocks and lowering springs = soon to be buying new shocks!
they are not made to operate beyond a certain range- lowering causes them
to do that and the main seal fails inside = new shock
ck MrHeelToe and Excelerate on here in the black market- sponsored sales threads
or their websites for more info
phone calls are accepted by both for direct personalized information
Fogs37 (11-27-2011)
Fogs37 (11-27-2011)
Im very happy with the TEIN SS, which beside having a threaded collar to move the lower spring perch and adjust car height, the shocks are designed to give the same
amount of travel as stock- even though lowered (a major bonus not found in other brands)
and the trick part: the top adjustment for oil flow rate- changes dampening from setting 16 super stiff-race track use, down to to 0, which makes the car wallow
so 2-4 clicks is great for a wife pleasing amount of bumps absorbed
It will seem to hop over bumps rather than go thru them
does increase ride stiffness from that perspective- but you didnt want to lower the car and get performance shocks and springs to have it ride like an old lady car, right?
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
4drviper
09-23-2015 07:42 PM
