Acura TL 99' sound system/firewall
Well, i just got some subs n stuff in and having some problems, first i cant seem to find where i can put thru the wire from my battery (do i need to drill a hole myself?) to inside and i heard i need to unplug my BOSE sub or something ? really new to these stuff and need some help, any help or information is useful! thanks again.
Above the parking brake there is a grommet you can run a wire thru. And yes unplug the stock sub if you are adding a sub.
x 2 i had to take loosed my driver side quarter panel to get my wire through, its really a pain but after that its nothing, you can get it, just might need a little paitence
anyone know how to take out the backseats? i can get the bottom one off but i need to take the hole thing out. do i just pull it off hard? or there some other way? thanks
5th Gear
actually its not hard to take out your back seat. and i just took out my factory sub. it allows alot more bass to come through from tha trunk. i also ride with tha armrest open in tha back seat.
The bottom is held on buy 3 bolts. Once removed you have to lift UP on the seat to unhook it from its top location.
Low & Slow w/Dubz On My
from what i have read when i was looking into this it actually is better to get a sub in a custom box...i think there is a kicker 8" u can buy with the correct depth..but from the reviews it doesnt sound as good as a sub in a box..
depends on how hard u wanna "bump"....i had a 12" kicker wit a kicker amp and that was good enough for me...i had to get rid of that becuz of the stroller i had to put back there...but imma look into gettin a 10" custom box so it sits flush against the side of the trunk so i can put things back there...
yeah thats what I think I am going to do..But prob mount it in the center of the truck near the opening to the rear..I want it to bump but not like retarded like the littles "yo's" around town.
i have two 12" subs in a sealed box. what kind of amp should i get? 800 watt two-channel or a 1000 watt mono-channel?
subs are jbl duals. should i stay within the same company for the amp or mix and match with another really good amp?
I just finished my wiring for my setup, using 1/0 gauge through the grommet fsttyms1 is talking about. Super easy, yes, even with 1/0 gauge. However, I used techflex to protect the wire beforehand, and pulled it through nice and slow. I grabbed some coathanger-type wire (actually it was picture-frame wire but same stuff), and poked from the engine side to the interior. Then I taped the big 1/0 wire to my guide wire, and pulled on through. It was probably the fastest firewall wire install I've ever done. To get some extra access in the engine bay, I unclipped some doo-dad next to the area, and moved it out of the way. Then clipped it back. Not sure what it was, but it wasn't hard to deal with.
I drilled in my firewall on the passenger side under the floor carpet maybe like 6-12 inches from glove box. I dont quite remember. For me running the wire through was the hardest part, everything else is easy.
Hello guys any body in here uses a LOC setup ? If so how do you wire it ? I have a mono sub and i'm trying to tap into the sub for the RCA cables but can't get it to work, not sure of what i'm doing wrong here. I did the wire on my 02 Accord and it's working okay, but it wasn't a Bose though.
AndrewS
19
03-14-2024 06:59 PM
