90,000 mile service??
OK, I bought my car with 87,000 miles back in the winter of '05, I now have 90,000, I've only changed the oil so far, I know I need new front brakes and a motor mount, what are some other things I should do now??
From Acura owners link:
Replace engine oil.
Rotate tires (follow pattern on page 264 of your owner's manual.
Replace engine oil filter.
Inspect front and rear brakes.
Check parking brake adjustment.
Inspect tie rod ends, steering gear box and boots.
Inspect suspension components.
Inspect driveshaft boots.
Inspect brake hoses and lines (including ABS).
Check all fluid levels, condition of fluids, and check for leaks.
Inspect cooling system hoses and connections.
#Inspect exhaust system.
#Inspect fuel lines and connections.
# = See information on maintenance and emissions warranty, last column, page 223 of your owner's manual.
Replace air cleaner element.
Inspect and adjust drive belts.
Replace dust and pollen filter.
Replace engine oil.
mada51589
05-03-2022 08:54 PM
Zonian22
11-14-2015 01:20 PM
asahrts
09-04-2015 05:55 PM
