2G TL Caliper Upgrade Question!!
Reading the DIY on the 1G TL forum:
Anyhow. Its a DIRECT BOLT ON. No fabrication, no special spacing, or "RIGGING" is necessary. This a bolt and play modification..
FRONT ROTOR: 95 LEGEND GS (2 DOOR COUPE MODEL)
Raybestos part number:RAY 96364 two of those for the fronts
BRAKE CALIPERS: 91-95 NA1 Acura NSX
The calipers you need are RAYBESTOS RC 10294 AND RC 10293
My question is: If those part Numbers are the same when Upgrading in a 2G TL-S??? I was just about to order the Legend Calipers but found out that I have some extra Cash to spend for the NSXs!! Need to Know if those parts are what I Need!!
Any reply Much Apreciated!!!!
All you need are the calipers. Nothing else special. You still use brake pads for the TL.
Also remember the right caliper goes on the left and the left on the right
About Legend Calipers!
So I heard that if you install them with the bleeder on the top side the Larger piston stays on the lower part and it was the wrong direction it doesnt matter?? Some say that would change the Bias or something like that.
I was about to buy them but I have this crazy idea that the NSXs were better if the Legends are the way to go it is Better and Cheaper yeahh!!! I quote them in autozone at 140+ bucks Refurbished/New.
What I found wierd is that he post the same part Number like he want us to buy the same caliper for both sides? whats up with that?
I dont care to flip it to bleed them if thats the only problem I would have a little piece of mind too..
gen2 TL= Raybestos 96 Legend LS-C calipers are FRC10627 & FRC10628
these have pistons the closest together in diameter- its a few MM, not enough to matter
I studied every set available for size difference-
that number gets you new bolts and sliders- remove from new parts and use on original TL bracket
There is a major misunderstanding on the caliper side swapping-
its got nothing to do with inverting the calipers- those who have the bleeder on the bottem are doing something WRONG- thats not how you get air out~
the TOP of the caliper is the top of the caliper!!
the legend ran them on the back of the strut- we use the front,
so in order for the bolts to all go into the stock TL mounting bracket - we install the left caliper on right side of car-in normal bleeder UP position,,and right on left
the calipers have a large L or R cast on the upper surface
cleaned old, or new sliders with caliper grease on them will prevent squeals
a little on the pad backs where they contact to pistons or outer fingers is needed.
The pads should have slight floating movement when its all done,,pump the brake pressure up and pads should rest about 1mm off the rotors when not in use
do NOT use the legend bracket- it only APPEARS to fit... until you try to tighten the bolts
this concludes my 25,000th!!! posting to azine in 5 years
Yikes
Yikes
HondaProtegeX2.3 (03-21-2012)
MechEng
CONGRATS 01tl4tl!
im definitely considering the Legend caliper route. only 60 bucks per caliper on rockauto.
would it be advisable to upgrade to stainless steel brake lines as well since it is dual piston?
Yikes
Yikes
I don't see confusion, I see a choice. The fact that you chose differently than me doesn't make you right any more than it does me. I know I'm in the minority on this, at least on this forum, but if someone is interested in the differences as skirmich seemed to be, why not give them the facts and let them decide.
Actually he did in a PM, So I did order them up this morning I will install them with the bleeder down (Like they should be Installed) I dont care about an extra 5-10 minutes to bleed if they do work like they were intended!! Soo
I Apreciate your time to Respond to all of You and Many Kudos to the Site, Acurazine always helps alot when Doing stuff to the old TL-S...
are you sticking a block of wood in the caliper to bleed it?
while I have not seen the nsx calipers, I do know the Legend dual pistons are not inverted to install- you walk them around the car and use on opposite side of strut--why is this a mystery or believed to be bad?
the bleeder stays on top= where it belongs-
They are fine like this, just different than `marked` (easier to identify in an assembly line bin of parts back in the 90s) from original use
If they didnt have L and R stamped on them- you wouldnt ever have known!
they fit many many vehicles besides acura
The actual differance in piston size- for this part number- is so small as to not matter to anyone but those running the Advanced group at track days
and they wont care- its a street Touring Luxury car!! and they are running a brembo BBK or wilwood 6 piston caliper and larger rotors--now those are rock and roll
Send you a PM 01tl4tl!!!
Thanks for the Clear Up! I dont have the Calipers Yet but yup I was on the impression that the Different Piston was around the same for both calipers thats why I mixed up situations here lol.
Then Legend Calipers = Same
NSXs Calipes = Inverted!
Got It! Thanks
Got It! Thanks
I dont know how they run nsx calipers only how legends were run and work for us
Never in my decades around cars have I seen a caliper with the bleeder on the bottem
Ok once,,, on a bike builder show where they screwed up and only way to mount caliper was inverted..but that was a show bike so didnt matter
but WHY would you run them upside down -when the piston size differance is so little and of no relative importance for our application???
Yes many parts are made with extra casting ports to use on different vehicles.
that caliper is on many other cars besides the legend series, the JDM cars got much better stuff than we ever did
Like I said, if the big L or R were not cast on the caliper top- you would never know there was even a different use for them
You would take box #27 and install on right side..as instucted
note the allen bolts found on gen3 brembos are not bleeders- they hold the caliper halves together!
if there is a lower bleeder on a multi piston caliper- its to assist in initial lower air removal.
With multi places to hide in the back of each piston- air gets trapped easily during install or when system open--as brembo cars would be for frequent work- race car type use
the real point here is the different sizes of the caliper pistons
If you just look up legend calipers on kragens- it had 3 pages of choices!!
fsttyms1 provided a spec chart with every year and models piston sizes
the ones I listed and use on my 01- are so close together as for it not to matter
Others were several mm diff- that is a big deal-
Will ck old pads for imprint size of pistons--visually its almost even and the pad wear was perfect/even across the pad,, down to the last 1mm of material
the bleeder goes on top-DONE
when skirmch does his there will be current validation on this
You can trivialize this difference all you want, but it's there for a reason, and I don't see a good reason not to take advantage of it.
The fact that you're happy with you set up is all well and good, but I've seen people reverse primary and secondary shoes on drum brakes with no problems or complaints. I've seen the same with directional tires. In neither case would I send the car out that way.
As far as validation I don't think we have to wait for anyone. I've got almost three years and about 50k on mine with great results, no uneven wear, noise, etc., but some of the honda guys have about 8 or 9 years this way.
Yes, a bleeder has to point up, but only when you're using it. For me that's 10 minutes every year or two. For the remainder of the time, it doesn't matter where it points. Done!
4 mm piston size differance,, when you look at used pads- on the back where the contact is made, is so marginal--
that for the average TL user on this upgrade:
stay with basic install- bleeder up where it will be easy to reach, and may even encourage them to flush the fluid a bit more often
Fresh fluid does wonders for pedal feel--when moisture gets in thru hygroscopic action, it makes the pedal feel spongy
overheating fluid gives similar result
You will hear guys at first track day, on OE pads and old fluid- saying: `wow! at the end of the session I had noooooo pedal`
those people.. we offer a quick lesson in brake fluid change trackside
can you post a link to where you got them from? or exact pn because RAY 96364 is not giving me anything usefull
dug a little more and found this way down in a different thread.....
rebuilt legend calipers not new
referance numbers: raybestos frc10627 frc10628
thats left and right with new bracket- you strip the new bolts and slider plates of the bracket and use them on the original TL brackets
everything else stays TL
http://www.rockauto.com/catalog/rafr...RC10627-481308
I went thru kragens-now Oreillys, online order and shipped for discount,
then returned old parts to local store for instant credit on the cores
this was before we knew they love getting modern TL calipers in exchange for those `hard to sell, old legend calipers`,,, LOL at them!
so it doesnt matter if you return to a place or store--its ok to bring what you have
back then -concern over not getting core refund when shipping to real place that knew what they were looking at--versus store ---where they said, `what are these--calipers`--ok
SS lines are awesome if in your budget at this time
remember to buy a $3 oil squirt can to prefill the calipers as much as possible before install
harbor freight tools has them or hardware store-parts store
buy 2 of the rubber `line plugs` a dollar each.. at parts store-cuts down on mess and air getting into abs modulator
I've had the NSX calipers on my car for 2 years and love them. I installed them with S.S. brake lines and Motul brake fluid, which I flush every 10 or 12 months. I love a FIRM pedal. Yes I had to swap sides with them and yes they work fine.
question: do you have real actual NSX `aluminum` verrrrrry expensive calipers?
maybe liberated from a wreck?
or ones that `FIT the nsx` but are made from the much heavier steel- that ours and other calipers are made from?
was there any issue with location of inlet fitting for brake line? longer brake line needed? or other issues--stories have varied is why I ask
WoW I quite forgot about this Thread hehehe My Calipers are all On now! Legend´s that is.
The Stopping bite got its upper Hand! its incredible comfortable to rely soo much on this Brakes, I was a Little exceptical cuz it wasnt OEM and my previous meets with Raybestos wasnt good either but HELL they did at least something right!
Now I need to replace my RED STUFFs cuz it sucks soooo baddd assss Need my YELLOWS!!! Well 2 good thing with the Red Stuffs is that compared to Yellows are virtually/Physically NON DUSTY...
The Amount of Dust the Red Stuffs does in 2 weeks gets done in One Stop with the Yellow Stuffs Really bad bad bad when you got Good Wheels...
Also the Cold Bite is Impressive, I was sooo used to the Shitty cold bite with the Yellows that was literally a Divine Intervention here!
But when it comes to Really really hard Stops thats where the line is drawn between Red and Yellow, The Fade is Impressive compared to Yellows...
Thats my Mini Review to Legend Caliper and EBC Red Stuff´s...
Pics? I dunno why I didnt take out of the Installation im used to take pictures of everything but I was sooo Hyped that I forgot! hehehe
which way did you mount the calipers?
try RacingBrake ET500 pads,,,for the serious street racer
The bleeders are On Top no issues at all, Also Now I understand the Original Legend bracket thingy you mentioned hehehe!
New Bolts and "Dusty Cushions" < (Forgot Actual Name) are Welcome!
I actually thinked the 2 Piston size difference would be bigger like the NSXs but isnt really that big! I was going to Install like it "should" be but Like you mentioned I rather bleed my Brakes more Often now that I roll on DOT5.1 than caring for Piston Sizes or Uses really, Having air/Water in my Brakes is not Fun!!
Wich Brand that Pads are? If they arent as Dusty like the Yellow Stuff and Brakes the Same it would be GREAT!
www.racingbrake.com or see our vendor MrHeelToe for them
get the pad series ET500
a little dust that you can correct by waxing the rims,,brake dust is a normal thing from contact and wear
the et500 has good stopping power that last thru all temps and speeds,, will blow your mind
Late brake when you want, repeated slow downs in the mountains no prob
I ran the 300 series, wife approved for quiet and her all too frequent `panic brake non-abs active` stopping from 80 to 20 or stopped,,, when not paying attention to traffic~
cars behind may have to take to the shoulder and sail past you-- as you are able to stop before a crash,,but they cant outstop you!
my 300s were subjected to more severe use than ever intended by the maker and wore out early,,so its 500s this time
Well they are in the same Price range than the Yellow Stuffs!
Im goona try them once my Red Stuffs are gone!
How about the ETs800s? but im Wondering about Rotor Life with some aggresive pads.
HOLY! Have you heard Experiences with their OEM Size Floating Rotor Replacements????
Im getting hyped about them...
http://www.racingbrake.com/TL_3_2L_I...2067-381-5.htm
But at 340 each isnt exactly cost effective...
their standard slotted rotor with curved inner vanes are the way to go for street drivers.
the rotors will go thru 5+ sets of pads before they are toast, and never need surfacing during that time. You may not have the car anymore by then
800s would be for track days, need operating temp in them and the bite would be too much normal use, but when braking down 40-80 mph every 15 seconds on a race track = they get reallly hot and cool just enough to be effective for the next corner
note--your rotor life will be reduced by harder pads and track days,,
but we bought them to go play,,you want to play = you must pay
