2007-2008 acura tl 3 spoke steering wheel
Does anyone try to fit 07-08 Acura TL 3 spoke steering wheel on a 2gen TL?
I did some research and since our facelifted 2 gen TL ( 2002-2003) has dual stage airbag, it will probably be compatible with the latest Acura models.
Does anyone here can give me more information regarding to fitment? and modification that I need to look at?
Thanks.
Thanks.
All Acura wheels should "fit" but as mentioned, you're going to have to come up with a way to retrofit all the wiring for cruise, stereo, etc.
And PLEASE, if you even consider trying this, disconnect the battery, wait about an hour, then remove the airbag before you do anything. I don't want to read about you in the obituaries.
And I'm assuming you know, you'll have to buy the 07/08 airbag as well. Makes it a pretty costly exercise.
So what you mean is that the 07 08 steering wheel should fit perfectly on my 2 gen tl w/o a problem? I know I need to retrofit the wiring and get 07 08 airbag. Thanks again
I just got the steering wheel with all the buttons. Does anyone know where I can get the steering wheel, airbag and wiring installed?
Does auto body shop or any audio shop will do the job for me? How much would it be?
Thanks .
Thanks .
well considering it may not be a direct plug and play it may be pretty costly to have done IF any one will even do it. You may want to try yourself. Its not hard to do.
