zaino claybar
I'm not sure about the Zaino bar as I use the Mother's one, but you can usually get a couple of uses out of it. What I do is break the bar in half. I can usually get about 2-3 cars out of half... then I use the other half with the same results. After that I usually chuck it and buy another. You can also tell by looking at the bar itself. If it looks too dirty... you're better off throwing it out....better to buy a new bar then to scratch your car!
Received 1,080 Likes
Really depends on the car and how much gunk it has on it.
I highly recommend cutting the clay bar up into a lot of little pieces and using one piece for each major part of the car, hood, trunk....
I use one clay bar per car. They aren't that expensive, well compared to a new paint job when you drag a piece of dirty clay across your paint.
