Would just a slight amount of moisture cause my headlight to not go on?
I just had a new headlight housing installed since the old one was smashed in my recent accident. Its raining pretty hard all day and I noticed some moisture on the inside lens, my headlight will not go on. It was on for the past few days but it was dry then. My question is would even the slightest amount of moisture F- things up? Or is it perhaps a loose connection?
Condensation on the outer lens is okay but if it keeps fogging up it will leave deposits and will make your headlight cover yellow and foggy. Make sure the highbeam and turn sig are twisted in correctly. Sometimes if they aren't properly secure they will leave condensation.
since you had a recent accident and had your headlights replaced, it's more like a loose connection that causes the headlight not to turn on. Does the parking light still come on?
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Well I had this same issue and thought nothing would happen but I was wrong. The little water drops inside the headlight housing don't just evaporate and poof it's gone. Some of it drips down which if some of you may know the H.I.D ballast are right under the housing which is a little electric box and if water gets there which IT WILL your pretty much gonna have to go on a mission like I did my self. MY MISSION. My stock headlights (before I cleared them) would also get moister inside so I thought my bulb had gone out so I ordered some new ones. Then I get my new 9000k put them in and nothing I was pissed. So I called acura explained my problem and the guy told me it could be the ballast got water and that's why it's not working which the little ballast goes for $250 bucks. So to make a long story short I threw a good working H.I.D bulb away for nothing cuz it wasn't the bulb it was the ballast. Then found where the moisture was coming from it's where the ballast goes mounted under the light the seal was no good all i did was put some silicone and that's it so far so good after 2 months no leaks what so ever. Mission :banghead:
![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
Originally Posted by TypeSwork
My stock headlights (before I cleared them) would also get moister inside so I thought my bulb had gone out so I ordered some new ones. Then I get my new 9000k put them in and nothing I was pissed. So I called acura explained my problem and the guy told me it could be the ballast got water and that's why it's not working which the little ballast goes for $250 bucks. So to make a long story short I threw a good working H.I.D bulb away for nothing cuz it wasn't the bulb it was the ballast. Then found where the moisture was coming from it's where the ballast goes mounted under the light the seal was no good all i did was put some silicone and that's it so far so good after 2 months no leaks what so ever. Mission :banghead: ![Doh](https://acurazine.com/forums/images/smilies/doh.gif)
Did you take the bumper off to remove the housing/ballast? I assume that needs to be done.
Yup thats the mission take the bumper off. The headlight can stay on you just need the rights tools to take the ballast off from right under the headlight. I wasted $269 on the new lights and $250 on the ballast and yes there very delicate it's an electric board one drop might miss everything up.
![](http://community.webshots.com/s/image1/6/4/72/130360472JbppIV_ph.jpg)
Well- I found out the problem- A BLOWN FUSE. Don't know what caused it to blow to begin with. Hopefully it isn't a recurring (bigger) problem. I'll have to get a blow dryer and get rid of that little bit of moisture this weekend to see if the problem is fixed.
The problem with the set up is that the ballast is on the bottom of the headlight assembly and when you combine moisture and gravity you end up with water in the ballast. Repeat a few times and you end up with corrosion in the ballast which may cause enough problems to blow fuses. Once you start popping fuses on a regular basis your ballasts are done.
emailnatec
29
09-28-2018 04:27 PM
AmplifiedDetails
09-24-2015 02:55 PM
