wonder why my head light is not as blue as other TL
Guest
Posts: n/a
![Question](https://acurazine.com/forums/images/icons/icon5.gif)
hey guy, I was wondering Y my 02 TL-S head lights is not as blue as other TL. When I turn it on it is really blue and after 15 - 30 Sec or so, it doesn't look blue anymore and i was wondering if my HID head light is defective. Can you guy Help !
I have the same problem, my hid's seem lighter also. My situation is someone different though, mine were just stolen & the replacements were put in. The replacements don't seem as bright or blue as the older ones. I'm wondering if they seemed darker (brighter) because of dirt??
O.G.
Re: wonder why my head light is not as blue as other TL
well I saw alot of TL on the street and they all looks blue, and I know for sure that they didn't change the bulb, so that's y i'm seeking an answer from you guy
I am pretty sure it has to do with the voltage from the ballast. My friend has HID's on his 2001 Grand Prix GTP, He used a aftermarket kit. Anyway he can adjust the voltage and that totally changes the color. So if your voltage is low, it will look blue-er.. I don't now if there is a way to adjust it on the TLs, but I think it looks mucho better White rather than blue. You are putting out more light with the white, and the blue, well looks like the old school HIDs like the ones on Lincoln Mark Viii's. That's my 2 cents anyway..
And yes they will be blue-est, when you first fire them up. I think they take about 10 minutes to get to their true color. The high beam HID's have to heat up faster, at least that's what I have heard..
I also wouldn't be surprised if they do blue up with age.
Oracle Apps/Database Dude
Mine turned bluish over time 1 year 6 months. It is sorta bluer that the brand new TL. so my guess is that give it time and it will turn bluer. Consequently, I wonder what happens when out TL turns 7 yrs old. Dark Blue lights ?
Plus, another possibility, the bulbs u get happen to be not that bright... Honda's quality is not as good as we thought.. some of their bulbs are actually brighter and bluer... mine were too yellow so I requested a replacement and because my car was still brand new at that time, they let me do it... we changed for like 4 or 5 bulbs and finally found something acceptable...
O.G.
Hid's get bluer the more they are used..fact
Lower voltage will make the Hid bluer but.... You are keeping them in a warmup stage (like first 10 sec on regulare HID) and bulbs will not last long and you have less light.
Want your HID's bluer.......... Drive with them on all the time or get Ultinons
1.Can't adjust TL HID. some aftermarket kits you can, but bulbs don't last long and sometimes ballast blow up!
2. ten minutes to warm up more like 10 seconds
3. High beam HIDS??????????? not on a TL
Ahhhh your taking me out of context..
>Wow what a bunch of mis information
>1.Can't adjust TL HID. some aftermarket kits you can, but >bulbs .don't last long and sometimes ballast blow up!
I didn't say you could adjust them on a TL, I said on my friends aftermarket package you could, I've watched him change this adjuster and you can see the color change.
Okay my bad.. They automotive ones range from 1 sec to 15
seconds. I figured the color brightned with heat over time
as most flourescent bulbs do, it's just not the case with our
automotive HIDs.
Wasn't implying that the TL has HID High Beams. I know that
they don't. sorry, I didn't make it more clear.
I just heard that the high beam's have to be instantly bright for DOT regulations. I suppose so you can flash your high beams?
automotive HIDs.
![Cool](https://acurazine.com/forums/images/smilies/cool.gif)
the TL's headlights always look whiter when viewing from inside the car loking out, and bluer when you are looking at the TL head on. also, the '02's headlights are different from the '99-'01 headlights so they are not as blue.
rockyboy
01-25-2016 06:00 PM
RLX-Sport Hybrid
3G RLX (2013+)
43
12-16-2015 10:45 PM
