Wiring Modification For Homelink Unit
Old 12-31-2003, 04:53 PM
Southern's Avatar
I made a wiring modification to my homelink (garage door opener) which requires the ignition switch to be in (II) position for the homelink to work.
I did this modification because I did not like the fact that the homelink was powered with the key out of the ignition. On the rare occasion that I have my car parked in my driveway, anyone could break into the car, open my garage door and have access inside my house.
The modification was simple. I removed the spotlight unit and snipped the WHT/BLU wire going to pin 1 of the spotlight unit near the connector for the auto dimming mirror. I spliced the WHT/BLU wire from the spotlight unit connector to the YEL wire going to pin 1 of the auto dimming mirror connector.
With this modification both the spotlights and homelink will require the ignition switch to be in (II) position for them to work.
Old 12-31-2003, 07:07 PM
jpadilla's Avatar
awesome ... i was concerned about this too. always need to think like a wanna be thug (they might be too stupid to think of that though).
I'll see if i can do it tonight.
Old 01-01-2004, 12:19 PM
Southern's Avatar
I forgot to mention that the above wiring modification is for Acura's without the onstar system. For units with the onstar system the only difference is that you splice into the YEL wire going to pin 12 of the auto dimming mirror connector.
Old 01-01-2004, 05:07 PM
04AcuraTL6speed's Avatar
The homelink and map lights use the same power wire correct?
Old 01-01-2004, 10:20 PM
jpadilla's Avatar
actually, i'll try this using a bosch relay with the coil switch lead going to the ignition. then cut the WHT/BLU u mentioned and have one end going to the relay source and the other end to the relay drain. that way i don't over load the circuit for the auto dimming mirror and you keep the original circuit intact (just have a relay doing the switching). Let me know if you want the wiring diagram of how to do this.
Old 01-02-2004, 12:27 AM
Southern's Avatar
Correct, after the modification the map lights will require the ignition switch to be in (II) position for them to work.
Jpadilla, I thought about overloading the auto dimming mirror circuit however both circuits are feed from a 7.5A fuse and the map lights only draw 12.4W and the homelink can't be drawing more than a few watts. Assuming that both the homelink and map lights draw 15W that is 1.5A additional load on the circuit.
Reviewing the power distribution for the fuse which supplies power for the auto dimming mirror, depending on the model year certain options may exist.
For example for the 99-01 models the back-up lights are included in the circuit. For the 02-03 models the tension reducer solenoid, keyless receiver unit, and power seat control unit are included in the circuit but the back-up lights are not in the circuit.
This indicates that the circuit has been designed to handle additional loads, however adding a relay to utilize the original power circuit won't hurt but you will be adding the relay coil draw to the auto dimming mirror circuit. If the relay coil draw is more than 1.5A then you would defeat the intended purpose keeping the two circuits separate.
Old 01-02-2004, 12:45 AM
jpadilla's Avatar
[This indicates that the circuit has been designed to handle additional loads, however adding a relay to utilize the original power circuit won't hurt but you will be adding the relay coil draw to the auto dimming mirror circuit. If the relay coil draw is more than 1.5A then you would defeat the intended purpose keeping the two circuits separate.
Good point, I was actually thinking of not using the auto dim mirror and use a different source for the coil instead. The coil should not use more than 0.5 amps.
Old 01-20-2004, 06:24 PM
booooo
TL_Diplomat's Avatar
all this electrical talk makes me sick, but thats an awesome MOD!
SUPRMN84
10-07-2015 09:46 PM
27trains
4G TL Problems & Fixes
09-30-2015 09:44 AM
dirleton
09-29-2015 08:26 AM
Quick Reply: Wiring Modification For Homelink Unit
