windshield wipers help
I currently have everything OEM as far as the wipers go...if I want to purchase the Bosch Icons:
http://www.partsamerica.com/ProductL...r=Wiper+Blades
will that be all I need to install them? (does that include the arm & whatever else I need)?
It is the blade itself and the mounting clip to the OE arm
The spring arm is built inside the blade
Simple to install, remember to turn wipers on so they go
to up position then turn key off-
you can then raise the wipers clear of the glass to replace
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
