Will 2nd gen rl rims and tires fit 2nd gen TLS?
Hi, I'm wondering if Oem RL rims and tires will fit?
the rl rims are 8 with 55 offset and tires are 245/50/17
tls is 6.5 with 55 offset and tires are 215/50/17. Would the rl's rims and tires fit? I tried the tire rim calculator on here and it gave me this...
Inner Clearance:
19.05mm less
Outer Position:
extend by 19.05mm
Diameter difference:
1.18" (4.43%)
I just don't know exactly what that means? will they fit? If not will the rims and my current tires fit? If not will the rims and what size tire fit? Thank you
Inner Clearance:
19.05mm less
Outer Position:
extend by 19.05mm
1.18" (4.43%)
The offsets are the same so that's a good thing and you should be good but the RL has a wider tire so make sure it clears everything. Just from looking at the specs the wheels are the same except for the width.
Hey thanks, yes the bolt pattern is 120. Sadly I'm clueless about rims. I know the bolt pattern for current rims on tl are 114.3. So would that have to make the offset 48 like it says on the chart because their 8? Can I put different tires on these than? Thank u both for your help
