wierd sound?
Team Nighthawk Member
wierd sound?
im haraing this wierd sound every time i start up my car and i stand outside next to the rear driver side. i hear like a put putting sound coming from under the car like its coming from the exhaust or something? thanks
NiGhT rIdEr
Twards the left rear of the car is where most of the evap stuff is like canister, canister vent shut valve, bypass solenoid and two-way valve.
The noises you are hearing could be some on these which may be normal.
If not have the dealer check it out under warranty if still available.
The fuel pump??? It makes a "put put" sound like as if there's a hole somewhere, so I see that I'm not the only one with this problem.
Missing my Acura's
B93P TL Owner
Correct answer.
Any ticking noise you hear from the driver rear tire area is the evap canister. Completely normal operation here.
As for the put put noises I am not sure about that. I'll have to think about that one.
damn i hear the same thing in my 2003TL-S A spec..
but its from my rear driver side area....
it happens last night when i got into my garage.
with the engine idling, i hear the putting sound...
i thinks its a leak in the exhaust but i dunno...
after i rev the car a bit.. the sound was gone...........
if it comes back.. i'm gonna have to ask acura
2003 SSM TLS
I've got the same put put noise from the rear driver's side under the car. It's only at idle and sounds like a tiny exhaust leak.....touch the gas and it goes away. If anyone gets a confirmation from Acura on what this is, please share.
probably not a big problem but it annoys the hell outta me just because its not normal.
Originally Posted by chewi
OMG same exact issue ....
yeah but it sounds as my car is broke down and all b/c my boy just got a cls and his doesnt make any noise and my car is next to his making a noise. poor but i guess it is normal if everybody is having the same problem
mlody
12-04-2019 02:11 PM
DerrickW
11-15-2015 05:52 PM
