Widest tire size on stock 16'' ?
![Post](https://acurazine.com/forums/images/icons/icon1.gif)
Originally posted by baz:
I am not planing to lower my car,so what is
the widest rubber I can put on? 215/55
or 225/55 16 ?
or 225/55 16 ?
2000 Red Hot TL w/o nav
Burlwood Trim and Shift Knob
Wood Trim Set
Gutter Guard Grill
Photos Of My RED HOT TL
Guest
Posts: n/a
![Exclamation](https://acurazine.com/forums/images/icons/icon4.gif)
Originally posted by Red Hot TL:
instead of 225/55/16, you should put on 225/45/16 the circumference (spe??) is really close to the stock, 215/45/16 isn't that close. 225/45/16 works perfect.
Therefore, AR2=(AR1*TW1)/TW2.
AR2=(60*205)/225=54.66666667, close enough to 55 for me
![](http://www.acura-tl.com/ubb/biggrin.gif)
2000 3.2 TL, Paper maps.
Comptech axle-back exhaust.
225/55ZR-16 RE730s on OEM alloys.
205/55QR-16 Alpins on steel wheels w/covers (winter).
![](http://www.acura-tl.com/ubb/avatars/custom/goldtl.gif)
Pictures
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by Einstein on 09-28-2000 @ ]</font>
Guest
Posts: n/a
I have a question about all of this wheel stuff, after looking through the archives. I've pretty much decided to stay with 16-inch rims because here in Pittsburg we have potholes which would swallow larger rims with thinner tires, no sweat. But, I'm still wondering is there any effect of larger wheels/tires on the operation of the traction control system. Is it in someway calibrated for the traction characteristics of the stock tire? Would the operation of the TCS be in any way afffected by wider tires (eg 225/55-16), even on 16-inch rims?
sorry, my bad I was thinking about 17s and bigger, I'm so sorry, dudes.
Wood Trim Set
Gutter Guard Grill
Wood Trim Set
Gutter Guard Grill
![Smile](https://acurazine.com/forums/images/icons/icon7.gif)
I'm happy with my 225-55-16's, no problem with fit and as Einstein stated there is an almost perfect match with OEM. Also there is quite a bit of sidewall which protects the rims from scraping if you park too close to a curb.
2000 Acura TL, White Diamond Pearl, AEM CAI, 225/55-16 Toyo Proxes FZ'4s
I spoke to Comptech, and they told me to put 215's on the stock rim if i am replacing the tires, they said the 225's will look bad on such a narrow rim...I dunno.. I am still probably going to get the 225/55/16's because it matches the OD the best.
Ed
'99 TL Satin Silver/Ebony, Non/Nav, Comptech lowered, Comptech Air Filter Element
Pics of my TL
Pics of my Miata! Wadya think?
Ed
Pics of my TL
Guest
Posts: n/a
![Lightbulb](https://acurazine.com/forums/images/icons/icon3.gif)
The 225's pictures I've seen on TL's make it look more muscular. Once you've stared at them for a while, then you look back at the 205's, it's amazing how goofy the stock tires can look.
Pictures
Pictures
I am really happy with my 225/55 16. I park my TL next to another TL everyday that has stock tires. My car looks much better with the wider tire. My Potenzas have a very aggresive tread - looks great.
BTW - no rubbing or other problems.
Guest
Posts: n/a
I am glad when I took a look at my new Bridgestones that they are made in Japan. Buying USA Firestones seems to be a big risk nowadays.
Pictures
Pictures
Sporty X type
I'm glad someone else asked this question, 'cause I was looking at wider/ different tires, & maybe going with new rims, but in the 16" size. I don't want 2 (sorry RED HOT TL)go w/ 17,18,20" wheels & tires. I drive 2 much @ year, and them puppies get expensive 2 replace.
Einstien, if you go go down in "PROFILE" size, 2 say 225 from the 205 stk. size, wouldn't that be .750 less "TALL", but 1.650 wider tires? I'll check w/ the guy I know that owns a Goodyear store. He should know that, I hope. Gee, what type tires will I probably get??
Guest
Posts: n/a
Start reading here
http://www.tirerack.com/tires/tiretech/size.htm
The tire width is the driving factor. The aspect ratio then determines the sidewall height...
Pictures
Pictures
Sporty X type
![Thumbs up](https://acurazine.com/forums/images/icons/icon14.gif)
Ok Einstein, nice site for tire info..but I was never very good w/ math problems! I use an old tape measure. Just measured the stock tire, & it's about 7" across the tread, & about 25" across the tire (TALL). I only have a 215/55 to measure w/ and it's 8" tread, & 24 1/4" across (tall). Does this come out on the formula that way
Guest
Posts: n/a
![Arrow](https://acurazine.com/forums/images/icons/icon2.gif)
Just use the OEM tires size and find a good tire calculator on the internet. Maybe someone can post a link for you... I'm not sure where they are. Maybe you could do a search on the internet.
Pictures
Guest
Posts: n/a
These seem like they might be worthwhile:
http://www.dsm.org/tools/tiresize.htm
http://www.miata.net/garage/tirecalc.html
http://www.c5-corvette.com/tirecalc.htm
Pictures
Pictures
Guest
Posts: n/a
![Talking](https://acurazine.com/forums/images/icons/icon10.gif)
SPEAKING OF OPTIONS!!!
(I'm considering 500/35-ZZZ12 myself)
If you want to run 12-inch wheels:
For 35-series tires, you will want a tire that is 497 mm wide
For 40-series tires, you will want a tire that is 435 mm wide
For 45-series tires, you will want a tire that is 386 mm wide
For 50-series tires, you will want a tire that is 348 mm wide
For 55-series tires, you will want a tire that is 316 mm wide
For 60-series tires, you will want a tire that is 290 mm wide
For 65-series tires, you will want a tire that is 267 mm wide
For 70-series tires, you will want a tire that is 248 mm wide
For 75-series tires, you will want a tire that is 232 mm wide
For 80-series tires, you will want a tire that is 217 mm wide
For 85-series tires, you will want a tire that is 204 mm wide
For 90-series tires, you will want a tire that is 193 mm wide
If you want to run 13-inch wheels:
For 35-series tires, you will want a tire that is 460 mm wide
For 40-series tires, you will want a tire that is 403 mm wide
For 45-series tires, you will want a tire that is 358 mm wide
For 50-series tires, you will want a tire that is 322 mm wide
For 55-series tires, you will want a tire that is 293 mm wide
For 60-series tires, you will want a tire that is 269 mm wide
For 65-series tires, you will want a tire that is 248 mm wide
For 70-series tires, you will want a tire that is 230 mm wide
For 75-series tires, you will want a tire that is 215 mm wide
For 80-series tires, you will want a tire that is 201 mm wide
For 85-series tires, you will want a tire that is 190 mm wide
For 90-series tires, you will want a tire that is 179 mm wide
If you want to run 14-inch wheels:
For 35-series tires, you will want a tire that is 424 mm wide
For 40-series tires, you will want a tire that is 371 mm wide
For 45-series tires, you will want a tire that is 330 mm wide
For 50-series tires, you will want a tire that is 297 mm wide
For 55-series tires, you will want a tire that is 270 mm wide
For 60-series tires, you will want a tire that is 247 mm wide
For 65-series tires, you will want a tire that is 228 mm wide
For 70-series tires, you will want a tire that is 212 mm wide
For 75-series tires, you will want a tire that is 198 mm wide
For 80-series tires, you will want a tire that is 186 mm wide
For 85-series tires, you will want a tire that is 175 mm wide
For 90-series tires, you will want a tire that is 165 mm wide
If you want to run 15-inch wheels:
For 35-series tires, you will want a tire that is 388 mm wide
For 40-series tires, you will want a tire that is 339 mm wide
For 45-series tires, you will want a tire that is 302 mm wide
For 50-series tires, you will want a tire that is 271 mm wide
For 55-series tires, you will want a tire that is 247 mm wide
For 60-series tires, you will want a tire that is 226 mm wide
For 65-series tires, you will want a tire that is 209 mm wide
For 70-series tires, you will want a tire that is 194 mm wide
For 75-series tires, you will want a tire that is 181 mm wide
For 80-series tires, you will want a tire that is 170 mm wide
For 85-series tires, you will want a tire that is 160 mm wide
For 90-series tires, you will want a tire that is 151 mm wide
If you want to run 16-inch wheels:
For 35-series tires, you will want a tire that is 351 mm wide
For 40-series tires, you will want a tire that is 308 mm wide
For 45-series tires, you will want a tire that is 273 mm wide
For 50-series tires, you will want a tire that is 246 mm wide
For 55-series tires, you will want a tire that is 224 mm wide
For 60-series tires, you will want a tire that is 205 mm wide
For 65-series tires, you will want a tire that is 189 mm wide
For 70-series tires, you will want a tire that is 176 mm wide
For 75-series tires, you will want a tire that is 164 mm wide
For 80-series tires, you will want a tire that is 154 mm wide
For 85-series tires, you will want a tire that is 145 mm wide
For 90-series tires, you will want a tire that is 137 mm wide
If you want to run 17-inch wheels:
For 35-series tires, you will want a tire that is 315 mm wide
For 40-series tires, you will want a tire that is 276 mm wide
For 45-series tires, you will want a tire that is 245 mm wide
For 50-series tires, you will want a tire that is 221 mm wide
For 55-series tires, you will want a tire that is 201 mm wide
For 60-series tires, you will want a tire that is 184 mm wide
For 65-series tires, you will want a tire that is 170 mm wide
For 70-series tires, you will want a tire that is 158 mm wide
For 75-series tires, you will want a tire that is 147 mm wide
For 80-series tires, you will want a tire that is 138 mm wide
For 85-series tires, you will want a tire that is 130 mm wide
For 90-series tires, you will want a tire that is 123 mm wide
If you want to run 18-inch wheels:
For 35-series tires, you will want a tire that is 279 mm wide
For 40-series tires, you will want a tire that is 244 mm wide
For 45-series tires, you will want a tire that is 217 mm wide
For 50-series tires, you will want a tire that is 195 mm wide
For 55-series tires, you will want a tire that is 177 mm wide
For 60-series tires, you will want a tire that is 163 mm wide
For 65-series tires, you will want a tire that is 150 mm wide
For 70-series tires, you will want a tire that is 139 mm wide
For 75-series tires, you will want a tire that is 130 mm wide
For 80-series tires, you will want a tire that is 122 mm wide
For 85-series tires, you will want a tire that is 115 mm wide
For 90-series tires, you will want a tire that is 108 mm wide
If you want to run 19-inch wheels:
For 35-series tires, you will want a tire that is 243 mm wide
For 40-series tires, you will want a tire that is 212 mm wide
For 45-series tires, you will want a tire that is 189 mm wide
For 50-series tires, you will want a tire that is 170 mm wide
For 55-series tires, you will want a tire that is 154 mm wide
For 60-series tires, you will want a tire that is 142 mm wide
For 65-series tires, you will want a tire that is 131 mm wide
For 70-series tires, you will want a tire that is 121 mm wide
For 75-series tires, you will want a tire that is 113 mm wide
For 80-series tires, you will want a tire that is 106 mm wide
For 85-series tires, you will want a tire that is 100 mm wide
For 90-series tires, you will want a tire that is 94 mm wide
Pictures
Pictures
Guest
Posts: n/a
![Cool](https://acurazine.com/forums/images/icons/icon6.gif)
Here's a good tire calculator www.powerdog.com/tiresize.cgi
You can enter a group of tire sizes and out comes a comparative table. Here below, I believe are the stats on the closest 16-inch sizes.
..........sidewall  Diameter  Revs/Mi  Dif
205/60-16, 4.8 in, 25.7 in, 785, 0.0%
225/55-16, 4.9 in, 25.7 in, 783, 0.2%
215/55-16, 4.7 in, 25.3 in, 797, -1.5%
205/50/16, 4.4 in, 24.9in, 811, -3.1
225/50-16, 4.4 in, 24.9in, 811, -3.2%
215/50-16, 4.2 in, 24.5in, 824, -4.8%
225/60-16 5.3 in 26.6 in 757 3.7%
As Einstein says, the 225/55's are the closest diametric match to the OEM tires.
2000 TL Firepepper Red
2nd Set of OEM Alloys Waitin for Snows
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by DrBill on 09-29-2000 @ ]</font>
Wood Trim Set
Gutter Guard Grill
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by Red Hot TL on 09-28-2000 @ ]</font>
Sporty X type
dude, don't say that, everyone's got their own style, I like to say "dude", and "gay" since that's all I hear all day long at school, sorry everyone that I'm addicted to those words.
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by Lrpba300 on 09-29-2000 @ ]</font>
Guest
Posts: n/a
The TCS works because it senses a difference in wheel speeds. Therefore, as long as the tires are all approximately the same circumference, you're OK.
As for calibration to the stock tire traction, I really don't think that's the case.
Pictures
Pictures
Sporty X type
![Wink](https://acurazine.com/forums/images/icons/icon12.gif)
Red Hot..just kidding w/ ya..u joked w/ me about using 2's so much, I had 2 differ for your sake only! It's cool "DUDE"
it's a bit tiring, gotta leave the keyboard for the "2", and then come back and forth...
Wood Trim Set
Gutter Guard Grill
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by Red Hot TL on 09-29-2000 @ ]</font>
Moderator Alumnus
![Red face](https://acurazine.com/forums/images/icons/icon11.gif)
Einstein....have you noticed any speedo inconsistencies when you moved up to the 225/55?? I believe the 225/55 are a bit "taller" than stock. Thinking about upgrading the rubber...just curious.
Thanks.
Thanks.
![Angry](https://acurazine.com/forums/images/icons/icon8.gif)
Ok, read the whole topic before POSTING SOMETHING that is a repeat!! Or try Ctrl+F to search the page.
Wow, Einstein you must be sore from cutting and pasting all that.....oh nevermind, you must have typed it since there is no other way to transfer information in Windows, you must be tired from using alt+tab to switch between windows and remember that information , and then re-type it....and......
"So Lone Starr, now you see that evil will always triumph, because good is dumb." --President Skroob
www.distributed.net
www.distributed.net
Guest
Posts: n/a
The 225/55-16 tires would be "off" from the stock 205/60-16 by exactly - 1.5 mm.
Diameter of 205/60-16(stock): 652.4 mm
Diameter of 225/55-16 : 653.9 mm
Difference : 1.5 mm - that is millimeters !!
You would not spot the difference in height even if you stared at it !! You will need a precision instrument to measure the difference. That is as close as it gets !
Thanks Einstein for enlightening me on this.
Some additional diameters to ponder over...
225/50-16 - 631.4 mm
215/60-16 - 664.4 mm
205/55-16 - 631.9 mm
Hope this helps....
2000 3.2TL/Nav Naples Gold Metallic - Bone Stock till now.
Hope this helps....
Guest
Posts: n/a
sounds like we have a new expert ![](http://www.acura-tl.com/ubb/smile.gif)
The tires aren't accurate to a millimeter anyway. In fact, consider the tire changes diameter 12-15 mm through it's life as it wears anyway.
Pictures
<FONT COLOR="#800080" SIZE="1" FACE="Verdana, Arial">[This message has been edited by Einstein on 09-30-2000 @ ]</font>
Pictures
Guest
Posts: n/a
Originally posted by Pawel:
So guys, if I get 225/55's how much off my speedo will be?
I'm telling you... the speedometer would only be off 1 MPH from stock when traveling over 120 MPH. That's as good as it gets.
Pictures
So will tires with 225/50/16 be ok?
My car would be slightly lowered with Koni shocks and Eibach springs.
I see that there is only a 3% difference. Will this affect the car that much?
nuldabz
09-03-2015 05:49 PM
Mugen TSX
Eastern Canada
09-01-2015 11:05 PM
