Why rub??????
Why rub??????
I just bought a set of 18 x 7.5 with 235/40/18. and the offset is 45. I am rubbing the back tires whenever i hit a bump, are my tires tooo wide or what? will 225/40/18 rub? thanks alot!
BTW I am using Eibach spring.
Why rub??????
see i told all those fukers at the CL forum this, with the eibach drop i would have gotten 48-50mm offset rims
...Damn your $hit is low and the tire is scrubbing, you need to start shaving or rolling fenders either one...Or change rims, which would suck...Good luck...Shyne
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
yup i think it's the tire width because 45 offset on 7.5" wide rims should have been enough; 225 would have been better in this situation. also i don't think 235 is the suggested tire for a 7.5" wide rim...so you go the the mfr's site and look up the tire and size to see what the ideal rim width is.
Retired MOD
1 Post
Re: Why rub??????
first the factory rims offset is 55. Yours is 45 than means the rims are sticking out more. Sencond you should have 225/40/18 tires. Third the springs have nothing to do with the rubbing, they never do. Also check for a aligment. If the toe is off, it might cause it to rub. Good luck. ![Big Grin](https://acurazine.com/forums/images/smilies/biggrin.gif)
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
