Who here install their own spoiler? I need tips.
Old 12-24-2003, 02:49 PM
Flounder's Avatar
I bought one recently & want to install it in a few days. Those that have installed their own spoiler, do you have any tips on helping me do my own install?
Old 12-24-2003, 02:53 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
was it new or used?
Old 12-24-2003, 06:22 PM
Mr Hyde's Avatar
Put masking tape all over your trunk where the spoiler pedstals would touch the car, and also over the drill sites. That will help prevent scratches from when you are postioning the spoiler.
Use magic markers to draw your outlines since the marks will just wasjh off with water, and once everything is lined up, just peel the tape off.
Old 12-24-2003, 07:24 PM
Flounder's Avatar
Originally posted by fsttyms1
was it new or used?
Brand New. Painted the White Diamond Pearl I wanted.
Old 12-26-2003, 11:32 AM
BlingBling INSPIRE 32V
songoku's Avatar
Go here for the ACURA installation instruction.
https://hondacura world.hostasaurus.com/Merchant2/instructions/tl/RearWingSpoiler.pdf
(no space between hondacura & world.)
Old 12-26-2003, 06:08 PM
Flounder's Avatar
Thanks but I have those instructions. I just wanted extra info from those that have installed their own.
I installed mine on X-Mas using Mr Hyde's tips. Thank you sir.
Old 02-19-2004, 01:36 AM
From the instructions on https://hondacura world.hostasaurus.com/Merchant2/instructions/tl/RearWingSpoiler.pdf (no space between hondacura and world), it says to also use a template, cap nuts and rear protectors for the installation. I bought my '00 TL spoiler painted from www.spoilerdepot.com . The instructions call for using the "set screw method" and I think the instructions provided by the link above seems to be easier. The problem is that I do not have a template, cap nuts or the rear protectors because they were not included with the oem replica spoiler. Instead I had 4 set screws, 4 phillips screws, gasket material, 4 washers, and 4 lock washers, along with the spoiler and the wiring harness coming out of it. There are also two red plastic things that have "3M" engraved on it and I think it has something to do with the wiring harness. The instructions were also not very clear as it did not even give directions on how to connect the wiring harness for the LED brake light. For now, the spoiler is sitting in my garage until I find out what I really need to do (which instructions to follow) to get the spoiler mounted. It would be great if someone replies with the experience of installing a replica TL spoiler with the parts that came from www.spoilerdepot.com Any help is appreciated. Thanks.
BoricuaTL
04-08-2016 01:08 PM
nanos
11-12-2015 08:41 PM
09-17-2015 09:01 PM
TxRzrBk
09-17-2015 01:07 PM
EE4Life
09-11-2015 10:13 PM
Quick Reply: Who here install their own spoiler? I need tips.
