who flushed their brake fluids at 30k?
Old 06-12-2003, 09:33 PM
The Doctor
UW RL's Avatar
my dealer told me it's recommended. but who does it?
Old 06-12-2003, 10:48 PM
Chemmech's Avatar
I am going to change my brake fluid myself at 25K. Over time the fluid absorbs water, then braking performance and reliability starts to diminish. On older cars changing the brake fluid really makes a difference.
Old 06-12-2003, 10:50 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
i have 113,000 on mine and its still brakes just as good as new.
Old 06-13-2003, 02:27 AM
The Doctor
UW RL's Avatar
i guess i won't do it anytime soon then.
Old 06-13-2003, 03:39 AM
limitedTLS's Avatar
i thought i was like once a yr
Old 06-13-2003, 07:13 PM
Someone once told me every 2 years regardless of miles. Just every 2 years. I've had my car over 2 years and have not done it yet...but will soon. I agree with Chemmech's statment. I think that's why ya do it once in a while.
Old 06-13-2003, 08:06 PM
l33t
Darkshear's Avatar
I want to do this, just to be safe, but how the hell do you drain all the brake fluid out of the system?
Old 06-14-2003, 12:13 AM
acur8's Avatar
Read the owner's manual maintenance schedule. It says for both normal and severe service, change brake fluid every 36 months.
It's a matter of time, not mileage. When getting brake service,
a fluid change is fairly simple. They just add more clean brake fluid to what they would have to top off anyway.
Old 06-14-2003, 02:52 PM
Red Hot TL's Avatar
I did it 2 weeks ago when I changed my brake pads. What you do is after you change the brake pads, there's like a little valve thing on the clamp. You have it closed, have someone in the car push the brake pedal a couple of times, then hold it all the way down, then you release the valve, the brake fluid comes out, close the valve, THEN now you can release the brake pedal. Do each wheel a couple of times to make sure there's no air in it. After you do one wheel, you add more new brake fluid. Also you need to do it in an order on the TL. First do passenger side rear, then driver side front, then driver side rear, last one is passenger front. Do it til it's clean fluid coming out of the valve on every wheel then you're set.
Old 06-15-2003, 06:53 AM
l33t
Darkshear's Avatar
and this is while car is running or no? maby stupid question, but the brake fluid doesnt exactaly move freely unless the electrical system is on....
Old 06-15-2003, 04:30 PM
Edr0e's Avatar
Brake Fluid is a B|TCH!
Old 06-15-2003, 10:02 PM
Chemmech's Avatar
I've changed the fluid on my other cars, but not the TL yet. I used to be a mechanic so I use a special tool and an air compressor. Here's the link, the kit cost me around $300.
http://www.vacula.com/usa/produkte/f_produkte.shtml
Look under Products,then brake service, then brake bleeder drain man.
Old 06-15-2003, 10:05 PM
Chemmech's Avatar
The only thing more irritating than antifreeze (makes your skin itch and stink like antifreeze, yuck!) is brake fluid.
I used to be a tool maniac. Got a tool question? Just ask me.
Old 06-15-2003, 10:41 PM
l33t
Darkshear's Avatar
eheheh you said tool ehehehe
Old 06-16-2003, 01:51 AM
The Doctor
UW RL's Avatar
how much does it usually cost to get a brake fluid change at a local shop? I am sure dealers charge an arm and a leg. and suggestions? I don't think I will be able to do it myself, although all of my mods have been done by me. and i mean ALL.
Old 06-16-2003, 03:04 AM
Chemmech's Avatar
Snap On tools that is. :o
Old 06-16-2003, 03:39 AM
Red Hot TL's Avatar
I did it with the key turned to "II" position, but I didn't have the car started. I believe that if you have the car started, the brake doesn't get "hard" after you keep pressing it. But if the engine's off, everytime you step on the brake to pump it, the pressure doesn't go away so it'll get harder and harder to pump and you want the pressure so the air won't get in the lines.
Old 06-16-2003, 12:24 PM
Oracle Apps/Database Dude
2001TL4KCdude's Avatar
Who's got it done at the dealer or an autoshop and how $?
Old 06-16-2003, 12:51 PM
Zed's TL's Avatar
Brake Fluid Change
I just had the brake fluid on my 2000 SSM TL changed at 30, 723 km. It cost $40.00 CDN at Toronto Honda. They also flushed my rad for $60 and changed the oil for $28. The brake pedal feels firmer and I hope this will extend the life of the calliper piston.
I have often found that Honda dealers offer better prices than do Acura stores. Terrace Gate Acura is the exception; they offer the lowest dealer service in the GTA.
SidhuSaaB
05-30-2020 12:40 AM
adrian_s2k
1G RDX (2007-2012)
23
01-12-2016 04:25 PM
LeVeL
10-18-2015 04:19 PM
lanechanger
10-13-2015 10:56 AM
95oRANGEcRUSH
09-25-2015 12:50 PM
Quick Reply: who flushed their brake fluids at 30k?
