Where can I install this???
I got a Kenwood KVT-911 DVD system and the kenwood DVD navigation this week.
http://www.kenwoodusa.com/product/pr...productId=2375
http://www.kenwoodusa.com/product/pr...&productId=747
Where can I put it? I don't want to lose my stock radio. Is it possible? Please help!!! I have a 2002 TL-S without navigation.
Hmmm... well, if you don't want to remove your stock radio you could have it custom mounted above the radio (where the little notepad tray is) or below the radio.... near the "ashtray". No matter what you'll probably have to do a custom installation if you do not want to remove the Bose.....
Dont really, first you got to get all the wires you need, install where you want, make sure connections are right, then make a custom faceplate. There are probally numerous steps I have left out, id suggest a pro install.
My suggestion was simply stating that if you remove the factory radio you'd have a place to put it.... you're still going to need a professional install (most likely)..... but if you remove the stock radio you'll probably need less custom work other then a faceplate.....
cycdaniel
12-17-2019 10:58 AM
pistacio
09-26-2015 09:45 AM
