Where can I get a cheap front subframe rear beam?
I brought this $500 2000 TL3.2 as a project car. After one week fixing this and that, now the biggest problem left is the rotted front subframe rear beam. Anybody knows where can I find a cheap one in Toronto?
After reading this post from beginning to the end, I believe it's the part 1 needs to be replaced.
https://acurazine.com/forums/second-...member-867198/
When I look really close, seems only rear passenger side corner is badly rotted and that piece seems can be disconnected from the rest of rear beam. Is that possible to just replace that part, not the whole rear beam? The reason is I don't have a crane to lift the engine.
From the looks of those pictures, I would replace both #1 rear beam and #11 front beam.
Find the OEM part #'s for both of those and search ebay.
Also, you can search local salvage yards, across the country, for them on car-part.com.
Good Luck!
Good Luck!
jray906
3G TL Photograph Gallery
18
04-22-2011 09:13 PM
