When should I change belts 100K?
I know I should only change the belts when there is some wear. But when is that? 100K is most likely too early but I really don't know what a warn belt looks like. Will there be cracks or discoloring? thanks in advance
You wouldn't worry about accessory belts unless it is contaminated with oil. If you want to change them, change them when you do timing belt at 105k as manual suggested. Normally, bad belts would show some signs of cracking.
mugen_kid
Nov 13, 2015 10:38 PM
