when I brake, it seems like the transmission jumps?
You need to be more specific with your symptoms. Is it when you first apply your brakes? How fast/what gear are you in when you are breaking that this is happening? It could be a transmission problem or something with the brakes...
i have that problem too. when you gradually slow down, say from 40 - 50 MPH (sometimes more, sometimes less) to ~10 MPH, it feels like the car stops sharply for a few milliseconds. its really hard to explain.. but i think i know what you are talking about. its really annoying, and i notice this happens in hondas. i havent experienced it in any other car.
Downshift?
You guys might be talking about when the automatic transmission downshifts as you are slowing down. The lower gear actually is working to slow down the vehicle at that point. I know that sometimes I feel this.
To check if this is it, put it in sport shift. While driving, downshift early (while your rpms are above 2k will probably do it), but don't put your foot on the gas. You should feel the engine "brake" the car. If this is what you are talking about, this will probably be an exaggerated version.
I hope this helps.
I hope this helps.
feel it when turning
When I use to make turns in my previous olds intrigue, the car would downshift, and I could step on the gas and pull while the steering wheel unwound.
In my new TL, the car seems to slow down after the turn and the steering wheel does not unwind as readily. I makes it hard to pull out of a turn fast, feeling torque.
It does seem to work if I step a little harder on the accelerator, but not if I'm cautious with the gas.
If you guys are talking about when you're completely at a stop and braking...than it jumps....then it could mean your transmission. But if you guys are talking about when you're slowing down than I don't know. Cause on my car before my tranny went out....everytime I was at a complete stop with the brake down...the car would feel like it jumps a little. Cause that's what happen to me before my tranny went out so be careful.
"If you guys are talking about when you're completely at a stop and braking...than it jumps....then it could mean your transmission....Cause on my car before my tranny went out....everytime I was at a complete stop with the brake down...the car would feel like it jumps a little. Cause that's what happen to me before my tranny went out so be careful."
I get that sometimes when Im at a complete stop. I always thought that was because I barely step on the break when Im at stops. Shxt dont tell me my trannys about to go.
My car also "jumps" when at stop lights, but only in warm weather. I had the dealer look at it one time, but "they couldn't repeat the problem".
Anybody figured out why this happens?
Originally posted by 69tl
so matt, you're saying that it's not the tranny problem but the compressor for the A/C that is doing it??
Originally posted by pianoman41
I can only speak for when the car is at a stop, with your foot on the brake. If the sensation is occuring as you slow down, that may be a different situation.
thx
yea cuz my wife drove the car today and she felt the jump when she was at the red light stop, and she thought the car behind her bump into her. so if you saying the reason it jump is due to the compressor then that was the answer i was looking for..
thx
thx
Thanks for the info. I guess the warm weather -> A/C makes sense then, huh? :toothless
BTW, when you run your front defroster (on any car), it kicks the compressor on and blows warm dry air up against the inside of the windshield. The compressor stays on for the duration of the defrost mode.
mada51589
05-03-2022 08:54 PM
asahrts
09-04-2015 05:55 PM
