When Fog LIght Mod V2 Goes Bad...
:( Harminder Is Lost In
Well i did the fog light mod with the cathode today and well it worked. Only thing is when i used spot 9 on fudes for instrumental or watever it is, it didnt work. Then i used number 8 which is acc. Now it works and everything but i just noticed my cel is on. Cars running flawlessly. Any ideas? Can i reset at home?
Autozone here stopped doing that. They said you have to buy a scanner. Ill goto my friend/paint shop owner becuase he has one and can take care of that. Im going to try the ecu thing first. Having the fogs hooked to the acc fuse isnt bad, right?
bringin lead
not sure, but if i remember correctly, mine is plugged into #8? will check in a few minutes and post if different. did you follow the diy - thats what i did and didn't have any problems.
uhhhhhh..... i work at autozone. Who told you that?
'13 Hyundai Sonata
Ok this may sound stupid, but your high beams aren't on are they?
Even though you may have checked it 5 times already, check to see if you have everything correct.
Also see if you have power to that slot because there may be a short.
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
oyayjoe
09-12-2015 04:40 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
