When do you usually get brake service?
Just wondering when the brake pads wear out approximately. I have 17,000miles on the car right now and the brakes dont seem to hit as good anymore and the steering shakes alot when braking hard.
Re: When do you usually get brake service?
First things first though. It definitely sounds like you need your rotors turned, which will get rid of the shaking. And it can be covered under warranty. I, like many others on this forum, had my rotors turned under warranty. Mine was on my '02 TL-S at 14,000 miles. Some have had higher mileage than you and also had the service done under warranty. Just ask nicely at the dealership.
hello...
i have a 1 year old TL...the steering wheel shakes when I brake at fast speeds...what causes warped rotors? wear and tear?
i thought the shaking was due to bumpy roads...sometimes, the shaking is less severe...
thanks
thanks
HEAT. Heat warps rotors. Warped rotors have been problematic on all the new TL's. I had my rotors turned at 20K, and again at 40K; both times for FREE by the dealer (the second time was tough).
There is a TSB that tells the dealer to change to a different new factory pad and turn the rotors; push this on them.
To lessen the chance of warping your rotors don't ride your brakes down hills and don't use them hard at highway speeds; don't wash your wheels when your car has just been driven and don't drive through flooded roadways..
- get a car wash after a hot day, long drive
- spray water directly onto hot rotors after driving
- run into a pool of water in bad weather condition and rotors get cooled too fast
To almost 95% eliminate the chance of rotor warpping, you need to cryogenically treat the rotors. There are places that offer this service.
SidhuSaaB
05-30-2020 12:40 AM
asahrts
09-04-2015 05:55 PM
