Wheel well
Wheel well
I recently noticed that there is a difference in gap on the front wheel wells of my car. The drivers side wheel only has 1.5 inch gap between the tires itself and the fender pointing towards the cabin. While the passenger has 2 in gap.
When I drive I know the steering wheel pulls to the right.
I just lowered my car with a 1 finger gap all around and no camber kit yet, but this happened even before it got dropped
Here is the driverside gap:
![](https://img518.imageshack.us/img518/5144/10003183zd.jpg)
The wheel well damage:
![](https://img518.imageshack.us/img518/7043/10003151ks.jpg)
Any clue on how to fix this? It chewed up my drivers side tire, I don't want to replace it and have it happen again.
Thanks for the help
Thanks for the help
Well the tire shouldnt be hitting that. It appears that something metal hit that to dent and crease it like that. I would take the tire off to see if any thing suspension related broke
It has been in an acident before, but was on the paasenger side and did not hit the susension at all.
I had the car for 20,000 miles but noticed this about 1,000 miles ago.
I will check to see if it is the suspension hitting that part and making that dent.
I thought it was actually the tires, but I'll check.
The tire didnt do that, plus there would be different marks from rubbing, not a actual impact mark
so you're saying the front driver's side is lower than the passenger's side? happened to my friend's integra and he just swapped the driver/passenger springs and that seemed to fix the problem. *shrugs* dono if your case is due to uneven settling of springs though.
now that you say that it does look further back . Have you taken the wheel off to see whats bent/broke?
I took the wheels off a few days ago and everything seemed fine. I just had my friend take a look at it and said it might be something with my bottom control arm. He also said that I most likely hit something and damage a certain part, don't recall exactly what it was but I don't remeber hitting anything.
Will take it off tomorrow to take another closer look.
Originally Posted by Mr Hyde
Probably a bent control arm or something of that nature. Definitely looks pushed back to me in those pics, and you had to have hit something to do damage like that.
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
Well I took off the wheel today and nothing was hitting that area. Only the tires were close to it and I would assume that it would hit it when I go over bumps and stuff.
Nothing "appeared" to be bent, but I heard that from multiple people now. I will have me friend take closer look at it to determine the actual damage.
I hope it is an easy fix or fast one atleast.
2400 Watts in a TL...Why?
1 Post
there wouldn't be somehting there hitting that location.. Something you ran over hit there AND your suspension causing the visable damage/ discrepency. The fact that there is a impact mark gives the hint that something hit up inyour wheel well, the fact your suspension is off would support that. There wouldn't currently be somethign loose hitting that spot, that would be too ovbious.
I took it to a shop for a quick look and they said that my knuckle was messed up.
They said for me to get an alignment to determine the definate cause of it.
1 Post
well yiou can't properly align something that is broken or bent... Ifyour knuckle has damage to it then it may have to be replaced.. If they try to align your car and it won't properly align due to the damaged knuckle, they might charge you for the alignment, then a new knuckle, then another alignment after the new knuckle is installed. Ensure they won't charge you for the first aignment if the car does need a second one.
I think at this point it would be best brought to some one who knows what they are looking at as far as what is damaged and what needs to be fixed like the dealer.
Well I my friend is going to do the alignment for free, so I am not worried on that point. But I really need to take it to a shop like fsttyms1 said that know what they are doing. MOst shop that I go to just take a quick look and do nothing else.
My car pulls slightly also..when i got my alignment...the specs showed that my caster was off. Note, caster is supposedly not adjustable.
I've hit some major pot holes that blew my tires and pretty much had to put the rim into the garbage. Anyway, it could be a bent/damaged spindle..control arm. I couldn't really figure out which spindle/control arm is bent. You'll need to get the specs from the dealer and measure it.
JByron
01-08-2016 09:49 PM
