What 'size' (?) oil filter?
Hey...
Am going to switch to synthetic oil at my next oil change --- within two weeks. I'm wondering if there's any particular 'size' filter that I need to buy...or if there aren't 'sizes' - if there's any specific one I need. (I'm obviously buying my own oil and filter...I think I've only seen 5-30W synthetic here...not 5-20W as listed on our oil cap).
I've never had to buy a filter before, so I don't know what to look for when purchasing the correct one.... I have a 1999 TL. I'm not sure which brands are available in Canada - so please list any info I will need to purchase either a Mobil 1 oil filter or a K&N filter -- you guys have said they are comparable.
Thanks!
Thanks!
Originally Posted by jpadilla
if going synthetic, might as well go all out and get the mobile 1 M105 filter as well. I use 5w30 b thye way.
I did find a retailer that might carry the K&N brand though... and I believe the oil filter I would need - if going that route - would be: HP-1004...
Thanks...
Originally Posted by Street Spirit
....That's what I meant --- so if I'm able to find Mobil 1 oil filters here, I would need "M105"? I'm not sure if they are sold here in Canada, so I might not be able to go that route...
Thanks...
Thanks...
or the mobil 1 m104 filter works too. they arent needed though. the last time i had my oil tested, the contaminants level was the same with the mobil 1 filter and the fram filter
Hey StreetSpirit,
If you're making the switch to synthetic ... how long are you gonna run between changes? Some ppl are going 1 yr between changes (12000km-20000km) instead of the Acura recommended 6 month/6000km. Are you going that route? Once my warranty runs out, I'll definitely go synthetic.
- derrick
- derrick
So you've used the OEM oil filter while also using synthetic oil and found there wasn't any difference between the OEM filter and a high performance one? ....I guess it would save me some money to stick to Stock if there's no difference... Since the oil would probably last me longer than the OEM filter - would I need to change the filter even before the oil needs changing?
Derrick - I don't think I could manage 20,000km without changing the oil. Even if that's *physically* possible because of the longer-lasting synthetic oil, I don't know if I could do that *psychologically*!
![Wink](https://acurazine.com/forums/images/smilies/wink.gif)
Mobil 1 makes a 0W-20 oil now.
Also, you could use the Purolator Pure One #24458 filter. It's an oversized piece, and costs $6 here in FL.
I'd have no problems going to a 12000km change interval. I change mine about every 8000miles or so.
Todd
Todd
Head Wanker
fsttyms1 - What's the difference between the mobil 1 M104 and the M105?? I haven't been able to find any info on their website re: which one for which brand/model car.
...It would just seem too bizarre to me to go a year without changing the oil....
Eurotrash
Good question!
Based on the following website, I would say that the Fram X2 is the best and most readily available oil filter. This does not endorse any other Fram filter lines, as it turns out they're crap. But read this article: while not totally up to date, it's quite informative.
http://www.ntpog.org/reviews/filters/filters.shtml
Originally Posted by wanker256
I believe the M-105 is an oversize filter vs. a "regular" size for the M-104. Oversize implies that it has more filtering element.
Derrick - I don't think I could manage 20,000km without changing the oil. Even if that's *physically* possible because of the longer-lasting synthetic oil, I don't know if I could do that *psychologically*! ...It would just seem too bizarre to me to go a year without changing the oil....
yea there was no noticable difference in the amount of particles between the mobil 1 and the fram i used in the first 2 changes.
as for how long to go i change mine every 8-12,000 miles (not kilometers) ive had it tested every time and the oil was still in good shape. and mine was severe driving
Any opinions on the Fram X2 extended guard filter (XG3593A)? This filter comes sealed in a vacuum canister. I've picked up a couple of these to go with my Mobil-1 synthetic oil. They cost about $10. Is this filter a waste of money?
I use Amsoil 5W20 Full synthetic
Later
Originally Posted by NSXNEXT
Amsoil SDF44 best filter out there. Read the reviews...
[img]
[img]
TLS-RULZ -- thanks so much for the info! I had no idea it would end up being so easy to come by! ....Is that where you get your stuff? What's the price like?
Todd
Todd
yup...there's 0w-20 now, it's a bitch to find. most stores around my area don't carry it, so when you do find it, you might as well buy a few cases. mobil1 made 0w-20 especially for hondas and fords i believe, it's just their replacement for 5w-20 and also cars that use 0w-20.
