What size?
What size?
well i ordered the oem kit for my 03 TL-S about a month ago and i should be receiving it tomorrow or the next day. i printed out the instructions to installing the kit myself because i want to save the money and most people said that it's not that hard. the instructions for the front piece
(http://www.acurainspired.com/forums/...showtopic=2882)
says that you have to use a 3 mm drill bit and then a 10 mm drill bit. my dad has a drill bit set but they are not in mm. they're like (example)1/64, 3/5, blah blah blah. Does anyone know which size drill bit i should use?
I've tried using a conversion table specifically for drill bits.
http://www.minimadd.com/tool%20kit/D...rsionChart.htm
but there's not a fractional drill bit that will perfectly convert to 3 mm or 10 mm.
thanks though tatewaki.
ExcelerateRep
10-14-2015 08:20 AM
AcuraKidd
09-25-2015 11:18 PM
