What paint for brake calipers?
Old 04-03-2004, 12:17 AM
Happy with my STi!
thsiao's Avatar
I want to paint the brake calipers to red or something... what type and brand of paint would you guys recommend... seems to be an easy mod and looks nice! By the way who has done this and could you post pics? Which color do you guys think its the nicest?
Old 04-03-2004, 12:40 AM
tumas's Avatar
any sort of spray paint will work, you dont need brake caliper paint. that being said, imo your car's blue would be cool.
Old 04-03-2004, 12:42 AM
Happy with my STi!
thsiao's Avatar
So the process to paint it is just remove rims, cover disc brakes, and paint the calipers? Sounds tooooo easy to be true... how come people don't do it if its so easy?
Old 04-03-2004, 12:54 AM
tumas's Avatar
imho, its rice.
Old 04-03-2004, 01:54 AM
NYDesi80's Avatar
Originally Posted by tumas
imho, its rice.
True, I agree, unless its a true sports car, like I believe the Nissan Z has painted calipers. Someone correct me if Im wrong.
Old 04-03-2004, 03:18 AM
In Pursuit of Perfection
I recently just installed brembo rotors and painted my calipers red. painting it wasn't hard. You need high temp. paint not just any regular paint. You can get it at auto zone or anything like that. I used 1200 degree just in case but 500 degree is ok. All you have to do is cover the rotor with a plastic bag, use some cardboard to cover the fenderwell and spray away. Spray 2-3 layers let them dry and you're done.
Old 04-03-2004, 07:55 AM
@ slide or die @
etxxz's Avatar
Yeah, i bought some 900degree paint, but i want to pain the whole caliper...its just that i cant remove the break sys...the nuts are VERY TIGHT.
I want to do a kik ass job, anyone know if theres a trick to removing the breaks that doesnt involve using A LOT OF FORCE?
Old 04-03-2004, 08:25 AM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
you dont need high temp paint!!! standard brake fluid starts to boil around 250 or so deg. standard pain can handle pretty darn close to that. i have had regular paint on mine for years now and i auto cross mine and it still looks great. the key is to clean it good and get a good primer. if its not cleaned good it wont stick .
Old 04-03-2004, 08:27 AM
fsttyms1's Avatar
you may need to use alot of FORCE. it wont break any thing. get a breaker bar or use a pipe on the end of the wratchet
Old 04-03-2004, 12:07 PM
Linner's Avatar
g2 caliper paint is good and its relatively cheap
Old 04-03-2004, 12:21 PM
Happy with my STi!
thsiao's Avatar
What do you mean by get a good primer?
Old 04-03-2004, 01:17 PM
TL-S driver
goldendragon576's Avatar
I plan on doing it this spring when the weather gets nicer. I'm not into the bright colors, I'm going to paint mine silver to match the car. Just want it to look clean, and not too showy.
Old 04-03-2004, 02:17 PM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
high gloss black would look nice.
Old 04-03-2004, 05:56 PM
rrdy's Avatar
I used Folia Tec, it came in a kit, but u have to use a brush to put it on, but it looks real good. i choosed red.
Old 04-03-2004, 07:00 PM
@ slide or die @
etxxz's Avatar
hey thanks, i tried hammering too... guess ill just paint half of it. Thanks
*Edit* the oil will vap at temps >200*C/392*F ...i used high temp paint just incase the earth gets close to the sun... (joke)
Old 04-03-2004, 09:52 PM
Happy with my STi!
thsiao's Avatar
I have decided that I will paint mine red... during the summer as well when I have more free time considering that its time consuming.
Old 04-03-2004, 10:26 PM
Assman's Avatar
Just finished installing these today: I used high-temp paint just in case...
Before:
After:
Old 04-03-2004, 10:57 PM
derrick's Avatar
Foliatec ... that's what i use.
- derrick
Old 04-03-2004, 11:41 PM
El Presidente
dark inspire's Avatar
i dont know if any of you guys used a spraycan instead of the foliatec kit, but do you have to cover the brake pads? will there be any harm done if the paint gets on the brake pads?
Old 04-04-2004, 09:59 AM
Assman's Avatar
I used a spray can. Take the calipers off and clean them with a wire brush really good so the paint can stick to them. The key is to remove all the dirt and brake dust to expose the metal. Tape off all parts that u don't want painted cause spray-paint goes all over the place....
Old 04-04-2004, 10:03 AM
El Presidente
how hard is taking the calipers off? i mean i dont wanna take everythin apart and then not know how to put it back together lol
Old 04-04-2004, 11:15 AM
fsttyms1's Avatar
exactly that. a good paint primer. it will help the paint stick and last longer. good primers are like the high temp primers (used for engine blocks and stuff) they will help bond better to the metal (if it is a little dirty)
Old 04-04-2004, 11:47 AM
Pusha Z
Yup Folia-tec. I didnt have a chance to use it before I sold my TL-S but I still have the unopened package. I dont know if im gonna do it to my Z now because I plan on putting either Project Mu, or Wilwood calipers on
Old 04-04-2004, 02:57 PM
Assman's Avatar
It's quite simple actually. There's 2 bolts that hold the caliper to the bracket and another 2 that hold the bracket to the car. The bracket bolts will be very tight so just use a breaker bar and smack it with a hammer to loosen them. The pads mount on the bracket but they just slide right out. Installation is the reverse.
Old 04-04-2004, 05:24 PM
El Presidente
alright, ill give it a shot!
GWEEDOspeedo
01-15-2016 10:39 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
rockyboy
10-02-2015 10:45 PM
Quick Reply: What paint for brake calipers?
