What To Do (Headlights)
Ok well it is really not neccessary to fix but i dont like it, i was behind a car today at a stoplight and noticed from the glare from the car that one of my headlights is blue and the other is yellow lookin. The bulbs are 6K btw. I changed the bulbs recently (kinda) because of this, back in November and i still have this problem. I was looking around at the headlights and noticed that one headlight is Honda and one is DEPO. Could that be the reason the color is off?
well i would personally contact hidextra about that and before you do that i would suggest taking the bulb out itself and examining it to see if there is any problems with it.
also a question, did you use rubber gloves or did you touch the bulb part whatsoever during installation?
2000 acura tl FPR
i'm thinking it may be the ballast, swap the ballast from one side to the other and see if the yellow follows it.
another possibility...
if the color does not follow the ballast over to the other side...
does the light turn yellow as soon as you turn the lights on? or does it "heat" up and turn yellow? pics? i'm wondering if condensation got inside the headlight and rusted? i dunno could be far fetched.
00 ssm
Getting a used OEM one would be risky bc you never know how much longer it would be good for OR it may have the same issue as yours does. Best/cheapest route would be to get an aftermarket kit. Hidextra is often running discounts for azine members so you might be able to get the kit for less than $60 shipped. Couple months ago i got a 3000k kit from him for $51 shipped
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
2000 acura tl FPR
a single oem ballast at the dealership will run you 3-400. that's why i got aftermarket. i got a d2r kit from hidextra, i haven't installed them yet but when it warms up i'll get around to it. shouldn't be too hard, i'll have to solder a few wires but other than that it's plug and pray. my headlights aren't yellow like yours.... my headlight will work just fine when i turn the lights on, and then it'll just randomly turn off.
Traded in my
Ignitor is the part that the bulb plugs into, which then plugs into the ballast. Inverter, also known as the ballast, is the box that's mounted on the underside of the headlight.
2000 acura tl FPR
AmplifiedDetails
09-24-2015 02:55 PM
