What Is The Best-quickest Way To Race The Type S?
I WOULD LIKE TO KNOW THE BEST METHOD TO WIN A RACE OFF THE LINE AND DOWN THE STRETCH---- NEED EXPERT ADVICE
DO I USE THE MANUAL SHIFT ? WHEN DO I SHIFT ?DO I KEEP VSA ON? SHOULD I SHUT DOWN A/C , DO I NEED 5TH ?
Turn the AC off, close the moon roof and your windows. VSA off, SS mode. When you see the green, floor the car and shift when it hits 7000 RPM. Don't forget to turn up some pumping tunes.
What does the VSA do on a straigfht run to slow you down?
I would think it helps off the line in keeping yours tires from spinning
DO YOU NEED 5TH TO GAIN ANY HIGH END SPEED?
As a side note, if you floor it our cars are smart enough to shut off the AC temporarily.
And definitely hold 3rd as long as you can. 4th is like swimming against the current....
AZ O.G NoOldManVetteOwner
Turn VSA off, put it in SS, and slam on the gas. Let the computer shift the 1-2 shift for you, as it goes to redline anyway. Shift yourself the rest of the way, making sure you go to redline in every gear. Once you get to the 3-4 shift, make sure you hold it till just short of the fuel cutoff. That way, you get a little deeper into 4th gear.
09-15-2015 06:44 PM
Mugen TSX
Eastern Canada
09-01-2015 11:11 PM
