VSA ON or OFF?
AZ O.G NoOldManVetteOwner
I think VSA OFF gives you better times, because my VSA engages when I leave it on and i floor the car off the line. Some people argue otherwise, but i cannot see how VSA ON could be better at the track.
I turn VSA off and get moving a tiny bit before I mash the throttle to the floor. It seems to work pretty well, though I definetly need to get to a track and perfect it. It's just a technique that I've come up with recently and I haven't gotten a huge amount of practice yet. If you can find somewhere just to run your car for 30 minutes, develop your own technique for what you think is the best launch. A track is even better since you get times taken for you..
I turn VSA off and lower my tire pressure. VSA is a bit too aggressive (closing the VSA throttle body and cutting power) so you don't get very good launches.
I haven't found the right tire pressure yet, though. My best 60' time is still a relatively high 2.35 with the tires at 26psi... they still spin too much.
Jamus22
06-11-2023 10:08 AM
mada51589
05-03-2022 08:54 PM
