Viper Alarm - Need Help Please
Hello, my viper alarm is not letting me get into my car. i parked the car and the remote stopped working. it started beeping and the antenna was flashing. now i can't deactivate the alarm and i can't turn on the car. Is there any way of opening the door with the key and then disable the alarm itself?? or what else can i do??? Please help.
thanks
thanks
I'm not sure about the Viper alarm, but shouldn't there be some short of Valet button inside the car? Cause on my clifford alarm, if you open the door without disabling the alarm, you have to turn the ignition to the II position, and then press down the valet button once and press and hold it again till it goes off.
yeah there is a button on the side next to the wheel i'm not sure what it is...i will try that though. thanks a lot.......now my car is at me gf'd house 1/2 and hour way...i'm home now i'll try it later. thanks again
there is in fact, a small "push" button for the valet. That will pretty much reset it all. you put the key "on" then "off", press once, the do it again. that resets the alarm brain for teh car, not the remote. that should, in turn, re-sync with the remote.
07-16-2017 08:33 AM
