VIP LED "Puddle Lights"
I was wondering if anyone knew where to purchase the VIP white LED bulbs also known as VIP or puddle lights. I want to install them under my sideskirts as courtesy lights but cannot find the screw in type.
Ackniculous One
I bet cops love these or do they just come on when you open the door? That would be kinda cool. I don't know about all the time, don't need the popo attention. Damn, even when there is light out, those things are bright as a mug
Those look nice I do not see the style that you have on the companies website. Do they screw in? I have 5 5 white led units on each side going on when door opens but I want to replace them I think they are damaged.
No He Can't
Here's a big thread on them -- https://acurazine.com/forums/car-parts-sale-361/fs-2003-3-2-cl-type-s-6sp-navi-164150/
Let me see what else I can find...
EDIT: Here's a DIY from the TSX forum -- https://acurazine.com/forums/showthread.php?t=31551
'13 Hyundai Sonata
Can you wire these up to your courtesy lights so that they only go on when you open your door? or do you have to do the whole fuse thing that was stated in the TSX thread? I just found some on autolumination for sale so I'm going to have to think about and might end up doing this sometime during the summer, but I will most likely need all of your help.
LIST/RAMEN/WING MAHSTA 짱
Originally Posted by bigeshorte45
thats sick, how much do these cost?
2Poor 2Furious
Search "footwell lights" DIY. The wiring is the same cuz the footwell neons/cathodes/LEDs comes on when the doors open. You end up tapping the dome light wire at the passenger's side fusebox.
yup 2 wires... like toast said use the interior light dimmer and run the wires up through the wheel wells through the firewall..Its an easy install just timely...
Good bye 03 TL-S
I love the puddle light look on the first picture. The only way I would do this is to have it on when the door is open, otherwise it would look kinda ricey
ഥഎണഡഏ Fellas Inc.
i followed the TSX diy (i think posted further up). i used the PVC method.
1) cut 3/4 inch circles out of pvc pipe
2) drill holes in side skirt with hole saw bit
3) hot glue or screw (did both) puddle lamp into pvc ring.
4) hot glue pvc to side skirt (the under non painted side)
Blah Blah Blah
Originally Posted by Malayalee King
jlevis single LED ($40, google) tied to dome light so it fades out when i 1) close the door, 2 ) unlock but do not open door, 2) arm the car
A few years ago one member I remember he lived in Hawaii had 5 LED under his white TL the LED unit screwed to the side skirt with a nut It looked awesome now I can't find where they sell it.
Anyone know How to fix your Dome light if it doesn't dim any more?
I Wanted to add Puddle lights to a my LED door handle. But I needed slove this PROBLEM.
Sorry for the
DOME light problem
Sorry for the
DOME light problem
