Vibration when braking from 55+ MPH
7th Gear
Recently my 03 TL-S with 30K miles steering was vibrating pretty harshly when braking from 55+ MPH. Took it to dealer and pointed them to the various post on Acurazine on this issue and also to TSB01017. Dealer griped at first and stated this is wear and tear item but in the end they resurfaced rotors and replaced with new brake pads under "Good Will".
Thanks to all the folks that have posted feedback on this issue.
And many thanks to Acura for fixing this issue even tough they did not admit to faulty parts or design on their Acura!!
is still kickin!
same thing happend to me, but instead of takin it to the dealer, i took it to my uncles shop got brand new brembo rotars and new raybesto's pads for $550,how much did the dealer charge you to resurface them? around 600?
Resurfacing rotor's doesn't solve the warped rotor problem. When your rotors are heated by use again and again your warped rotors will come up again. By re-surfacing them there is less thickness in the rotor to abosrb the heat. So my estimate is in about 10k miles you will be at your dealer again with warped rotors.
Eventually you will need to purchase better quality rotors and use ceramic or OEM pads. Make sure that whoever tightens the lugnuts are using a torque wrench and not an airgun. Over torqued lugnuts warp rotors easily and break in the rotors and pads with easy to moderate breaking for 500miles.
joflewbyu2
08-18-2019 10:38 PM
GWEEDOspeedo
01-15-2016 10:39 PM
joflewbyu2
10-08-2015 11:16 AM
