vibration porblem
is making xxx movies
vibration porblem
my car shakes/vibrates when doing about 35-40 mph. before and after that everything is ok. i took off all my wheels and looked at the tires and there was no unusual wear. what problem do i have ?
Bad ball-joints.. I'm also getting very bad vibrations @ 45mph+ for being slammed. You'll need to get new ball-joints a.k.a front camber kit. Do not get OEM replacement ones.. #1. They suck. #2. They'll just re-wear themselves out. #3. They suck.
i have a new tranny and i have a front camber kit so i dont think the balljoints are needing replacement........what else could it be ? just a balance problem ?
Biggie B
I had the same problem your having and its not your tires or your balance, but do check them out first. Most likey its your drive shaft (The axle). I had both of them replaced and i have a nice smooth ride again. Look for aftermarket axle, uless you want to pay 1700 for brand new ones. This sucks but replace it before your tranny goes next. Good Luck to you. Biggie B
:( Harminder Is Lost In
Theres no problem man, its the gift of god in your car. He did that so when you have a female with you it would bring her pleasure. When alone either go 20 or 50. On a serious note get those wheels balance and youll be happy.
I think it's axle(s). Seems like most people on here that describe the shake at 35-45 end up with axles. Make sure you get NEW as opposed to reman. Good new axles are available aftermarket [places like napa, etc.] for a hundred or less.
MrHeeltoe
20
02-23-2023 01:54 PM
joflewbyu2
10-08-2015 11:16 AM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
