urethane suspension bushing help
Old 09-01-2015, 12:15 AM
8th Gear
milehightypes's Avatar
My 02 type s has some very worn out rubber in the suspension . I have been looking for a polyurethane master bushing set similar to what energy suspension and prothane offer. After countless hrs of searching I have not been able to find much of anything. Does anyone know either if such a set for the 2nd Gen tl exists, or if perhaps there is an accord (or other model) with which the tl shares it's suspension and thusly a bushing set? Any help is very appreciated
Old 09-01-2015, 02:46 AM
Skirmich's Avatar
Received 1,017 Likes on 867 Posts
Probably mentioning which part you need will help with your inquiry..
Old 09-01-2015, 07:35 AM
8th Gear
I am looking to replace All of the rubber suspension bushings with polyurethane.
Old 09-01-2015, 07:38 AM
Received 8,691 Likes on 6,705 Posts
Any reason why just replacing to OEM won't work?
Old 09-01-2015, 07:40 AM
8th Gear
Oem bushings are rubber, if it's possible, I would much prefer polyurethane.
Old 09-01-2015, 07:45 AM
Well aware ..
Just wondering what your aversion to rubber is..
are you allergic
13 year old rubber is obviously worn so new rubber would be lightyears' improvement.
Old 09-01-2015, 07:54 AM
8th Gear
Well aware ..
are you allergic
Lol. True new rubber is lightyears improvement over worn rubber, but in my experience new poly is lightyears improvement over new rubber. . . I just haven't been able to find it for this car...
Old 09-01-2015, 02:53 PM
rcb2000's Avatar
The durometer of the material is what you should be shopping not type of material. You want a stiffer suspension that's fine if your racing it around the track. daily driver just a waste IMHO
Old 09-01-2015, 06:22 PM
8th Gear
Strangely enough, I actually prefer the stiffer suspension both for daily driving as well as my frequent long mountain drives. I guess I'm not hard line against a stiffer than oem rubber, but haven't even been able to find a compkete suspension
Old 09-01-2015, 06:25 PM
8th Gear
Sorry, gotta live posting from a phone.... that should read haven't been able to find a complete suspension bushing kit at all. Hence my wondering if the tl shared it's suspension with another honda/acura vehicle.
Old 09-01-2015, 08:43 PM
Skirmich's Avatar
You wont find it.. There are some parts like the Radius Rod bushing that MOOG makes in Poly but most of our suspension parts are shared with the decaying 6th gen Accord chassis which is more popular than ours and still lacks Poly Support.
Your only choice is CUSTOM or live with Rubber + A couple of Poly Bushings.
Old 09-01-2015, 08:46 PM
8th Gear
Sad, but good to know. THANK YOU SKIRMICH!!
Old 09-10-2015, 11:57 AM
acutee's Avatar
21bux at autozone for a pair.
Old 09-10-2015, 12:07 PM
8th Gear
a
A pair of what? Did you miss the Part where this thread is about finding a kit with ALL the suspension bushings?
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
adreano17
09-29-2015 08:48 AM
MrHeeltoe
09-28-2015 05:43 PM
Quick Reply: urethane suspension bushing help
