underbody fender...
underbody fender...
Hi, I had my body kit installed about two years ago, and in the process of the install, the underbody fender ( i think thats waht it is called) had to be removed and later put back in....
about 10 days ago i had my tranny replaced, and all of a sudden yesterday the underbody fender came loose and is dragging across the floor. I wanted to know if they needed to loosen that up while doing the tranny install. ie is it their fault?
thanks
thanks
i have no idea what a underbody fender is. are you talking about the plastic cover that protects the engine from water and such?
1. i have no idea why you needed to remove it for bodykit install.
2. i dont think they remove that for a tranny install.
regardless you NEED to fix it ASAP, mine came loose cus of a mistake i made and it ripped off and bent my fender and such. its not a big deal just get a few retaining clips from acura and put them back in. should cost you like 20 bucks at the MAX. taking it to the dealer should be more, stupid stealership
