TypeS Vs stock TL
Header & Intake, should be pretty close...Let us know...
2000 TL - Laguna Green, Navi, Rear Spoiler. PIAA Hyperwhite HB's. 17" CL-S wheels with Bridgestone RE 730 - 225/45/17's. Soon to have Comptech Suspension, Sways & Axle back Exhaust.
Those two combo of header and intake, should give you about 20 horsepower, should be pretty close to a stock TL-S...let us know the results...
2000 Satin Silver TL, 17x7.5 ATP wheels with Pirelli 215/50/17 P7000SS, H&R OE springs, OEM spoiler, K&N filter, Tint all Around. Inspire Foglight Switch, PIAA 1700X fogs, Polarg M-12 corners.
You forgot your other weapon....Your wing..it should help you win!
Ed
Acura-TL.com - Forum Moderator
'99 TL Satin Silver/Ebony, Non/Nav, Comptech lowered, Comptech Air Filter Element, Inspire Tails, AEM Brake Pads all around, Comptech Axle Back Exhaust, "Guy Smiley" doll on the dash as my Co-driver...
Pics of my TL
Pics of my Miata! Wadya think?
Ed
Pics of my TL
If I'm not mistaken hasn't there already been people who have posted dynos after comptech headers and shown +25 hp gains???
Y2K Satin Silver/Ebony 3.2TL
AEM Short ram w/ custom CAI conversion | Magnaflow axle-back exhaust | Neuspeed Sport springs(modified: 3.5"F/3"R drop) | BOSCH platinum+4 spark plugs | Acura OE Wing | Mesh grill and bumper | Acura Indiglo Emblem | Mugen badging | Body color door handles | Polarg M12 sidemarkers | Opti-Blue Xenon HB's | Hiper Strobes F/R | 20%/35% Llumar Platinum tint | Razo RA42 Shiftknob | Alloy pedals | Blue neon exterior lighting | Rockford 10" RFP2410 Punch XLC subs | Boss Audio CLR60 600watt 4ch. amp | Escort Passport 7500 Radar/Laser detector
25hp gain from headers alone? Okay, unless things have changed seriously from preludes to TL's... no way. I remember people would have to get headers, intake, and exhaust to get like 22 hp. i wish it was that easy tho man.
'99 3.2 TL
Black/Black
Burlwood Shift Knob
Bodykit
Spoiler
Tint
'99 3.2 TL
Black/Black
Burlwood Shift Knob
Bodykit
Spoiler
Tint
Honda-Acura.net TL Forum Moderator.
1999 Silver with factory body kit, spoiler and burlwood instrument cluster and shift knob. Joshua Tree Wood dash kit. Hella air horns. Tint all around. Razo competition pedals. MOMO Sport 18"X7.5" with 225/40ZR Pirelli P7000SS. Weapon-R intake. Comptech springs, exhaust and headers. Inspire Tailights, homemade ram-air and Polarg M-12 front turn signals. Comptech front and rear sway bar. Axxis Metal Master front and rear pads. Mugen front grille. 2 Polk/MOMO 10" subs, Orion Xtreme 500.4 amplifier and Alpine CD changer.
My AcuraTL Homepage
NEW: '01 Acura MDX Silver Premium
Front 35% tinted windows. Running boards. Roof rack. Tailgate deflector. Moonroof visor. Rear mud guards. Razo premium white headlight bulbs. Matriz ion yellow fog light bulbs(courtesy of Snook). More to come later......
Acura-MDX.com Forum Moderator
I think a lot of people miss the point when they say "it adds 20 hp." To calculate real difference in power you have to take the area under the curve. The headers and intake will only add significant HP in the high end of the powerband whereas the tl type S's stock power is probably significantly higher in the low end of the powerband as well as the high.
Things like 1.5 times displacement, and 1.5 times as many cylinders.
For real though, the stock TL exhaust manifold is restrictive. The Comptech header is pretty high flow, so the gains are pretty damn big when you can get something that's not a choker to begin with.
And for once I think rice has a good point to add to the story.
I agree. Whenever anyone says "gains 20 hp" they mean peak hp. I think they should pick a designated rpm, like the stock power peak, and just measure hp gains there, so it will be uniform.
You always hear people saying "Well I got an intake which is 7 hp dyno'd, headers, which is 20 hp dyno'd, so I must have 27 hp." Which is not necessarily true, and most often NOT true.
The reason is because the 20 hp is just peak hp gain, suppose at 5800 rpm and also suppose it hiccups at 4000 rpm where the gain is only 2 hp. Well now what if the intake's peak hp gain is 7 hp at 4000 rpm, and kinda goes lean on the top end and loses a hp at 5800 rpm? Whoops, total gain at 5800 rpm is 19 hp, and total gain at 4000 rpm is 9 hp. Nowhere in the powerband is it 27 hp over stock. And no one should expect it to be that way either.
Kenny
TL
I saw comptech's dyno chat and it shows that
"17.9HP was max gain" "header+muffler"
So i'm looking at bout 20 HP gain. huh??
260hp vs 245hp "still -15HP"
What other options do i have??
Does Oil change helps? how bout spark plug?
oh by the way.. does any1 got new MSD ignition???
HOT, the 20 hp from your headers and intake are probably closer to 25 at the crank, because of what you lose through the transmission to the wheels. The 225 and 260 measurements are taken at the crank so you're probably closer to 250 vs. 260. Just an estimate... Of course the Type S has grippier tires yet has larger wheels...
John
2000 TL WDP Nav
John
2000 TL WDP Nav
i got stock wheels on right now with new tires. Does Type-S rims are havier than 16" rim?
LIST ANY POSSIBLE UPGRADES i CAN make!!!!
(dont say something like"get a turbo or NOS..please.")
so i'm pretty much looking at 250 VS 260?!
Shit if thats the case i think i'm gettin headers. I never knew the stock ones were that resrtrictive! i do know preludes stock headers are quite good, in fact Gen 4. rally preludes used the stock headers.
Rice: certain headers/exhaust affect the lower range, others improve higher range. I've seen this reported in the Great headers test. I believe that was the name done by SCC mag. a few years ago.
I am not claiming that it does, but it is dependent on many factors. So, don't be pessimistic. Also, the Type S might be a slow one. Never know.
* AEM SRI (blue)
* Factory Bodykit
* Type S rims
* Comptech Springs
* Inspire Tails
* Burlwood knob
* Tint
The headers and intake will help, but the big problem you gotta watch out for with that Type-S is the dual stage air induction, that's what's going to kill you. The Type-S has a much much much flatter torque and hp curve because of that, so he'll be pulling hard no matter where the RPM range is. IMO that's where the Type-S excels, yeah sure it peaks higher, but it's also flatter and that is what ultimately results in it being quicker.
I think the biggest differences race-wise btw the Premeium and the Type S would be the launch. I've seen a couple 0-60 vids of Type S's, holy cow they launch substantially meaner than our non-S's.
After I drop the break and bury the throttle, the tires squeal for a second or more and then there's a short lag period where the car is kinda figures out its rpm and speed, then the torque comes and you get goin like normal.
The S just blows right through the launch, right after the tires squeal, its off, no lag time after that. And that's what I think makes most of the difference.
If you want a closer race, go from at least 35 mph, where you can put the car in high rpm's and get a good momentum going.
I think the best you can do within reason is, intake, headers, exhaust, high flow cat (or test pipe), plugs, pulleys, v-afc.
That's a good basic start. I spose if you're really into it, you could do a throttle body. Ours stock is 64mm and the type S's is some 68mm ? or maybe ours is 60 and theirs is 64. Anyways, the Type S's TB is substantially larger, and along with it you'll need an intake manifold port match. (Type S TB costs around $180)
An Accord V6 owner is working on a Type S intake manifold transplant, but its expensive. ($900-$1000 for the part alone) Then you've got the install. Gotta find a way to actuate the butterfly valve with rpm's. I'll keep checking with the Accord guy and tell you all if anything's up. That's the Type S's main gain in torque.
A 2000 TL with i/h/e/vafc pulled a type s on the highway I believe. So with pulleys and a cat you'd be in good shape.
Kenny
TL
Kenny
TL
What do you guys use to keep yours so clean? Mine are nasty at times.
2001, Satin Silver TL w/ Navi.
Factory Bodykit
Comptech Headers
Comptech Exhaust
Short Ram Intake
Comptech Springs
Comptech Sways
Inspire Tails
CLS Rims w/ 215/50/17 Toyo Proxes T1-S for the spring, summer and fall
OEM Rims and POS tires for the winter
Wings West Spoiler (Being Painted)
Factory Bodykit
Comptech Headers
Comptech Exhaust
Short Ram Intake
Comptech Springs
Comptech Sways
Inspire Tails
at the local dyno store the comptech headers were shown to give a 18 hp gain at the wheels for the TL and i think it was 28 for the cl-s. i actually saw the chart for the tl because i didnt believe the guy when he told me. he did say that it was an unusually large gain for headers. guess the j series engines just have restrictive exhaust manifolds. as soon as i get a grand i am going to have the headers.....
99 MBP w/ alpine aftermarket nav/ vcr/ dreamcast (fm modulator so sound runs through speakers)/aem cai/aem pulley kit/comptech exhaust/ apexi v-afc/ eibach pro-kit
28 hp from the headers?? Sweet. This is a mod I definitely plan on doing.
One more thing, the TL-S weighs a bit more than a TL-P, so if modded well, a TL-P should make it a close race
Ahh, that would be me! Plus I had 18's on. Remember, everyone that said headers helps on the high RPM range is right. I did not notice much power gains in the low range, but in the high end you notice your RPM's racing faster.
CL-S
White/Ebony/Navi/Spoiler/Visor/Full Bra/Mud Guards/Cargo Net/Acura Car Cover/Tint 20%,35%, Rockford 250a2 Amp w/JL10w6 / K&N Drop in Filter. Comptech Springs/Sway/Headers Polarg m-6.
ok. I raced this guy works at jiffy lube.
his car was tatally stock cl type S.
After i changed oil i suggested to race each other. anyhow here is the results.
from 0.. he pulled on me fast.(one&half car length)
from 75mph. i somehow managed to keep even speed w/ Type S.(guess the header works.?!)
raced until 143mph.
So i guess from 0..you can't win over typeS.
however High speed racing can be pretty good match. I couldn't pull but i could pretty much manage the same speed with type S. (I used 3Rd gear till 115mph). i removed spare tire and 1/4 gas.
raced until 143mph.
1fatcrxnem1
22
06-01-2018 02:23 AM
handsom-hustla
11-13-2015 06:04 PM
sockr1
10-01-2015 02:31 AM
