Turning off AC
Turning off AC
I know what your probably thinking, "This guy must be an idiot...", I know how to turn off the AC with the navi and yes also you can hit the OFF button. What I am curious about, is there a way to turn off the AC without the Navi or by using the OFF button? Why you ask? Also because there are times in which it's too cold or I wanna WOT and I just want air running with no AC on. Because when you got an address inputed into the Navi and then you press the AC button, it clears out the address so you would have to reenter the address again. Thank you and have a wonderful day!
Richard
Richard
the address does not clear, whe u insert the address and the navigation is giving directions, just press AC set ur temperature then press return or map i think. leaves u same place as before.
I have another "idiot" suggestion. Try increase the temperature settings on the AC just a little above the outside temperature. That should release the compressor.
Just my $0.02.
Cheers !!!
Just my $0.02.
Cheers !!!
No, you are a dork.
Just my $0.02.
Cheers !!!
Just my $0.02.
Cheers !!!
Will it let you go above 97 degrees?
IBankMouse
06-13-2020 12:53 PM
SidhuSaaB
05-30-2020 12:40 AM
