turn signal problem...
Old 11-12-2003, 05:19 PM
njtls's Avatar
i bought some led turn signals for my rear..and they blink really fast...it causeed my fornt s to blink fast too...like they almost never turn off....i dont mind it too much...but will this cause a problem?
Old 11-12-2003, 05:38 PM
Tatewaki's Avatar
this is called hyper blinking. Since LED takes much shorter time to light up, it doesn't give enough time for the relays to kick in.
The solution: splice a resistor into the +ve line
Old 11-12-2003, 06:08 PM
njtls's Avatar
what ressiter should i use?....and i cna splice it into the wire by the bulb or soemwhere else...
also..is it gonna cause dmaage if i dont?...cause i dont mind it really..except the fronts dont really look like their blinking
Old 11-12-2003, 07:39 PM
njtls's Avatar
bump before i get kicked off the page...anyone?...i just spent 20 of my last 30 bucks on these bubls...i dont want to have to throw them away
Old 11-12-2003, 08:03 PM
Tatewaki's Avatar
I am not too sure about the value. I'm guessing about 500 ohm to 1k should work fine
Old 11-12-2003, 09:11 PM
TLS-Sun's Avatar
http://www.superbrightleds.com/1157.htm
middle of page. i got those and they work. $5/each.
Old 11-12-2003, 10:07 PM
njtls's Avatar
thanx tlssun....but i dont want to spend anytmore moeny....ok...if i got a resister...how would i wire it?...cut the wire and put it inbetween?
SidhuSaaB
05-30-2020 12:40 AM
navtool.com
31
11-16-2015 08:30 PM
ROSSARONIE
10-02-2015 11:46 AM
Greengecko
09-16-2015 08:19 PM
Quick Reply: turn signal problem...
