TSB's needed...
is the Mighty Favog
TSB's needed...
I'm taking my 03' Type-S im to a dealer tomorrow for the following warranty problems but I would like to have the TSB printouts before I go.
They are:
-Oil Jet kit for transmision
-Squeaky groaning armrest when you put your arm on it.
-Squeaky driver's seatbelt
-Peeling black exterior tape from door trim
Does someone have access to these before I pay AllData or someone else money to get em'?
They are:
All Hail the Chief
I don't know if people are still getting in trouble around here for mentioning the "other" site, but they have a separate forum that lists all TSB's for your vehicle.
Think "world".
-JPritch
Think "world".
-JPritch
Bulletins for 2003 Acura 3.2TL V6-3210cc 3.2L SOHC
Safety Recalls
TSB Number Issue Date TSB Title 03-022 NOV 03 Recall - Timing Belt/Tensioner/Water Pump Replacement
General Recalls
TSB Number Issue Date TSB Title 03-030 OCT 03 Campaign - Engine Timing Belt Tensioner Replacement
03-017 SEP 03 Campaign - PCM/Fuel Pressure Regulator Update
02-027 SEP 03 Campaign - Automatic Transmission Defect
Service Bulletins
TSB Number Issue Date TSB Title 04-008 MAR 04 Navigation System - Operational Malfunctions
01-041 FEB 04 Engine - V6 Engine Oil Leaks
04-004 FEB 04 Computers/Controls - HIM Module Updating
01-026 JAN 04 Engine Controls - ECM/PCM Reprogramming
03-032 NOV 03 Engine Controls - MIL ON/DTC's O0301/P0305 (Misfire)
00-037 OCT 03 Brakes - Brake Disc Refinishing Guideline
03-029 OCT 03 Brakes - Brake System Lamp Comes ON/Goes Off
03-028 OCT 03 Navigation System - Incorrectly Displays Phone Numbers
91-050 SEP 03 Interior - Seat Belt(s) Slow to Retract
03-015 AUG 03 Audio System - Remote Controls Don't Work Properly
98-005 JUL 03 Drivetrain - Revised CV Joint Boot Band/Installation
97-040 MAY 03 Keyless Entry - Description/Identification/Programming
01-017 MAY 03 Brakes - Pedal/Steering Wheel Vibrate When Braking
00-019 APR 03 Antitheft System - Type 2 System Operation/Programming
03-010 MAR 03 Engine Controls/Emissions - DTC's & Monitors
03-006 MAR 03 Engine Controls - Idle Speed Inspection
03-003 FEB 03 Interior - Power Seat Rail Synchronization Update
03-001 JAN 03 Emissions - MIL ON/DTC P1457 (EVAP) Set
Safety Recalls
General Recalls
Service Bulletins
TL = Tranny Lubrication
Automotive Recalls and Technical Service Bulletins for 2000 Acura TL V6-3206cc 3.2L SOHC MFI Safety Recalls TSB Number Issue Date TSB Title
IMPORTANT NOTICE
The American Honda Motor Company, Inc. has requested ALLDATA restrict access to Acura and Honda repair information by individual consumers. You will unfortunately not be able to register for access to Acura or Honda vehicle repair information, technical service bulletins or recalls.
We kindly request that all comments should be directed to:
American Honda Motor Co., Inc.
P. O. Box 2206
700 Van Ness Ave.
Torrance, CA 90501
Honda: 800-999-1009
Acura: 800-382-2238
Additional information is available of various websites, if you have issues you should contact your local dealership. The above is just an FYI and should be used as such.
additional resource:
http://www.recalldata.org/2000/index0001.shtml
use 2000 Acura TL Recalls in your search on the web....
Good luck!
- 02-010 APR 02 Recall - Passenger Air Bag Replacement
- 01-030 AUG 01 Recall - Front Seat Belt Buckle Replacement
- 00-020 JUN 00 Recall - SRS/Seat Belt Indicator ON
- 03-017 SEP 03 Campaign - PCM/Fuel Pressure Regulator Update
- 02-027 SEP 03 Campaign - Automatic Transmission Defect
- 04-008 MAR 04 Navigation System - Operational Malfunctions
- 01-041 FEB 04 Engine - V6 Engine Oil Leaks
- 04-004 FEB 04 Computers/Controls - HIM Module Updating
- 01-026 JAN 04 Engine Controls - ECM/PCM Reprogramming
- 00-037 OCT 03 Brakes - Brake Disc Refinishing Guideline
- 03-029 OCT 03 Brakes - Brake System Lamp Comes ON/Goes Off
- 03-028 OCT 03 Navigation System - Incorrectly Displays Phone Numbers
- 91-050 SEP 03 Interior - Seat Belt(s) Slow to Retract
- 03-015 AUG 03 Audio System - Remote Controls Don't Work Properly
- 98-005 JUL 03 Drivetrain - Revised CV Joint Boot Band/Installation
- 97-040 MAY 03 Keyless Entry - Description/Identification/Programming
- 01-017 MAY 03 Brakes - Pedal/Steering Wheel Vibrate When Braking
- 00-019 APR 03 Antitheft System - Type 2 System Operation/Programming
- 03-010 MAR 03 Engine Controls/Emissions - DTC's & Monitors
- 03-006 MAR 03 Engine Controls - Idle Speed Inspection
- 03-003 FEB 03 Interior - Power Seat Rail Synchronization Update
- 03-001 JAN 03 Emissions - MIL ON/DTC P1457 (EVAP) Set
- 02-020 AUG 02 Air Bag System - Occupant Position Sensor Initialization
- 02-015 JUL 02 Air Bag System - SRS Lamp ON/DTC's Set
- 02-012 MAY 02 Clutch Master Cylinder - Fluid Leakage
- 02-006 MAR 02 Front Seat Back Panel - Loose/Detached
- 02-005 FEB 02 Emissions - EVAP System Testing and Diagnostics
- 96-025 DEC 01 Navigation System - Component Exchange Program
- 99-041 NOV 01 Navigation System/A/C - Operation/Testing
- 01-016 SEP 01 PCM - MIL ON/DTC P0128 or P1486 Stored
- 99-051 AUG 01 Exhaust - Muffler Paint Peeling
- 00-037 AUG 01 Brake Disc - Refinishing Guidelines
- 01-004 JUL 01 Wipers - Smear or Streak the Windshield
- 01-011 FEB 01 Radiator/Condenser Fan - Runs Continuously
- 01-003 JAN 01 Alarm System - Sounds By Itself Intermittently
- 01-001 JAN 01 PCM/Fuel Pressure Regulator - Hard Starting
- 00-039 DEC 00 Electrical - Wiring Terminal Replacement Instructions
- 00-032 NOV 00 Moonroof - Squeaks from Moonroof Seal
- 00-025 AUG 00 Body - Windshield Molding Deformed
- 87-015 JUL 00 Audio System - Warranty Non Warranty Exchange/Repair
- 00-018 JUN 00 Door Switch - Squeaks
- 00-016 MAY 00 Door Mirror - Vibration
- 00-015 APR 00 Accessory Moonroof Visor - Creaking Noise
- 00-014 APR 00 Squeek or Creak From Driver's Seat
- 00-008 MAR 00 Torque Converter Oil Seal Installation Tool
- 98-037 FEB 00 Brakes/Traction Control - ABS/TCS Lamp ON/DTC's Set
- 99-041 FEB 00 TQI OF THE DVD NAVIGATION SYSTEM
- 00-002 FEB 00 Rear Door Sash Trim is Wrinkled
- 98-011 NOV 99 Computers/Controls - Aftermarket OBD II Tester/Software
- 99-040 OCT 99 Troubleshooting DTC P1456 and P1457
- 99-043 SEP 99 TQI Information (2000 3.2 TL)
- 96-025 SEP 99 Navigation System Exchange Program
- 90-007 MAY 99 Steering Wheel Off-Center Adjustment At TQI
- 98-004 APR 98 Audio Unit Anti-Theft Labels
- 98-005 APR 98 CV Joint Boots - New Band & Tool
- 92036 NOV 92 Vehicle Fails State Inspection Emissions Test
IMPORTANT NOTICE
P. O. Box 2206
700 Van Ness Ave.
Torrance, CA 90501
Honda: 800-999-1009
Acura: 800-382-2238
Good luck!
Originally Posted by AcuraTl203
theres a recall to replace the timing belt? is that on an 00 too?
tallyrlx
3G RLX Audio, Bluetooth, Electronics & Navigation
02-26-2016 03:44 PM
