Trunk torsion bar help
Old 05-14-2002, 09:26 AM
I just called my local dealer trying to order heavy-duty torsion bars (the ones that come with the OEM spoiler) but they told me that I would have to order the spoiler with them. Does anyone have a hook-up that can get me the HEAVY-DUTY torsion bars, not the stock ones? Please help!!! Thanks.
Old 05-14-2002, 10:26 AM
NSXNEXT's Avatar
Received 1,080 Likes on 661 Posts
Call another dealer. I just called mine and they said you can buy them separately for about $45.
Old 05-14-2002, 12:23 PM
Thanks NSXNEXT...too bad there are only 3 dealers within the area... Hopefully one of the other 2 will sell me a set.
Old 05-14-2002, 12:36 PM
NSXNEXT's Avatar
If not, call Park Ave Acura. They'll sell you a set.
201-587-9000
Old 05-14-2002, 12:41 PM
Mr Hyde's Avatar
Wow I never even realized there was a heavy duty set. from reading the manual I thought you kept the stock ones and just had to reposition them, and that a special tool was needed to adjust them alhough some people did teh same using crowbars and hammers.
Email Tim, he should be able to get em for you.
Old 05-14-2002, 12:44 PM
Acura TL-S
ZodiakTL's Avatar
201-587-9000
just called and ordred them, and they are $35
Old 05-14-2002, 12:47 PM
I just called one of the other local dealers and they told me that they could order them and that they would be $35. The part number is 08F13-SOK-201R2 for those that are interested in upgrading their torsion bars. You might want to double check on that part number because I won't be getting my bars in until monday, so I won't be able to confirm that part number is in fact the HEAVY-DUTY torsion bars...I'll let you all know.
Old 05-15-2002, 12:02 AM
Mstyle's Avatar
I'm sorry..What is a torsion bar?? Please help me understand..Is it a stablizer or something like that....And what is wrong with the stock one...
Old 05-15-2002, 05:30 AM
Trunk torsion bars are springs that open up our trunk lids. If you open your trunk, and look right below the stock sub, you will notice 2 grey bars going from one end of the trunk hinge to the other. These are the stock torsion bars. When you add a spoiler to your car, the extra weight is too great for our stock torsion bars to be able to pop open the trunk, therefore, they need to be replaced with heavier-duty ones. There is nothing wrong with leaving the stock ones in, but if you want your trunk to pop open the way it did before you had a spoiler, then you need these...otherwise, it will just barely open when you press the trunk release button.
Old 05-15-2002, 06:16 AM
Purchased: April 28, 2001
edgalang's Avatar
The heavy duty ones are black and are color coded red and green on one side to tell you which one is the right or left spring.
Old 05-15-2002, 06:29 AM
Which side is which color?
Old 05-18-2002, 10:13 AM
1999TL's Avatar
Can anybody confirm if that part number above is a good number? I called to my local Honda dealer(no Acura dealer around here) and he said it wasn't a good number. I'm trying to see if the accord uses the same spring.
Old 05-18-2002, 10:25 AM
That part number is a good number...
Old 05-18-2002, 01:07 PM
BlingBling INSPIRE 32V
songoku's Avatar
Hey John,
If you're going to install them for yourself, make sure to get the torsion spring tool. It's really hard w/o the tool. It's about 8 bucks and make your job a lot easier.
TRUNK SPRING TOOL (part# 08M10-SM4-100)
(For your information, you can get the tool from either ACURA/HONDA dealer. Call them and give them a part#)
Old 05-19-2002, 02:08 AM
Only $8??? That's cheap! Thanks Paul!!!!!!!!!!
Old 02-19-2004, 01:54 AM
After reading the posts, my question is:
Are the black heavy duty torsion bars included with the oem spoiler? My trunk flops closed in any slight wind or if I'm parked on an incline. I complained to the dealer and they "adjusted" them but I still have the same problem. I have a 2003 tl-s with the dealer installed oem spoiler. Any help is appreciated.
Old 02-19-2004, 03:17 AM
Flounder's Avatar
The dealer should have upgraded your torsion bars if you bought your TL w/ spoiler attached. I said SHOULD but you never know, these guys would cut any corners they can in order to make $$.
Look at the bars, the heavy duty ones are black & the originals are grey. Check out my recent thread when I installed my heavy duty bars:
http://www.acura-tl.com/forum/showth...threadid=71304
Since you're at it check out the bottom of your OEM spoiler under the spoiler light. The words "ACURA" should be marked if not the stealer did not give you a true OEM spoiler but rather gave you a cheaper after market one in order to charge you for the full OEM price & make extra $$.
Old 02-19-2004, 11:34 AM
songoku's Avatar
Just pop up the trunk and see if you have gray torsion bar or black one on your car. Gray torsion bar is stock one w/o spoiler. That's what comes with the stock car. OEM spoiler comes with black heavy duty torsion bar.
If you have OEM spoiler and has gray torsion bar on your car, obviously, whoever did the install didn't put the heavy duty torsion bar.
Old 02-21-2004, 11:10 AM
Well I just looked at the torsion bars and they are grey. Pretty much what I expected. My spoiler does say ACURA underneath so it is OEM. I hammered the dealer on the price of the car so they screwed me on the torsion bars and didn't give me my valet key. What else??
Old 02-21-2004, 12:35 PM
NYDesi80's Avatar
GO BACK TO UR DEALER!! THat is unacceptable regardless of what price you paid. He accepted to do the deal at that price he has to give u all the parts...I believe when u buy the factory spoiler the springs are included and not seperate.
Option 2 is go to another dealer and complain about the trunk not opening up all the way, and then tell them that someone told you about some springs in the trunk and maybe they are defective. Act dumb about it, and since you have a factory spoiler they will replace those springs for u under warranty. There is no way for them to tell if you bought the car with the spoiler on at time of purchase or u added it on later on. Their systems dont know. Just act dumb if you chose this option.
Old 02-22-2004, 12:30 AM
El Presidente
dark inspire's Avatar
do new torision bars come w/ the WW spoilers as well?
Old 02-22-2004, 12:51 AM
Flounder's Avatar
No way. New torsion bars are only there if the OEM spoiler was installed by the dealer & if that dealer decided to upgrade the bars. As you may know some will not.
Old 02-23-2004, 02:23 PM
songoku's Avatar
In other words, if you purchase OEM spoiler from ACURA, there's heavy duty torsioin bar inside the spoiler box. And it's upto installer whether he wants to change it or not.
tsx_boy
12-13-2019 08:33 PM
copmagnet82
4G TL Problems & Fixes
06-29-2016 08:09 AM
hashbrown
09-29-2015 12:13 PM
Quick Reply: Trunk torsion bar help
