TRANS Replace, HELP NEEDED
Old 01-21-2004, 03:07 PM
snowdude1's Avatar
OK,
so my trans is gone and the dealer said that they are going to replace it. however, i remember a while back that there was a thread saying that the new trans that they are putting in limit power or something? what is the deal with that and is there anything that i need to know b4 letting them replace the trans next monday?
Marc
Old 01-21-2004, 03:21 PM
nick79's Avatar
yes some people said they feel less power. i dont think this is true. the new trannys are alot better and i think they might of fixed the issue with the past tranny problems.
Old 01-21-2004, 03:30 PM
Dr. TLS
It apparently gets rid of the shift lags so you might see improvement in 1/4 mile times!
Old 01-21-2004, 03:48 PM
TL-S driver
goldendragon576's Avatar
I haven't noticed any differences since my new tranny, then again I had my headers put in at the same time so I guess I wouldn't. I don't remember that thread so if someone could explain what this loss of power is. Thanks!
Old 01-21-2004, 04:31 PM
2002 TL Type S
Hokie D's Avatar
I haven't noticed any differences in power. Also, I must have missed out on the "snappier" shifting tranny. It still has lag, feels a tad worse than the factory tranny.
Old 01-21-2004, 04:59 PM
2007AcuraRL's Avatar
Trannys replaced after Sept. 2002 also have the ECU swapped out. The new ECU has reprogrammed shift points --- The car wont try upshifting to 5th gear so easily (to prevent engine lagging while driving at low speeds) and the roughly 1/2 sec delay in the shift between 2nd and 3rd is eliminated too.
Old 01-21-2004, 09:17 PM
snowdude1's Avatar
can you explain why the hell they would put a new ecu in the car, i dont understand wouldnt this have other effects too?
Old 01-21-2004, 10:59 PM
DivinDude's Avatar
If you read the NHTSA report on the acura-cl.com site (under the transmission failure forum) .. you'll see why Acura reprogrammed the shift points. They found that their hardward couldn't handle what the software was telling it to do. Therefore, rather than upgrading the physically tranny, they reworked the software .. hence .. the new Ecu.
Old 01-22-2004, 07:52 AM
Just agree and go away...
LargeOne's Avatar
I had my tranny replaced a little while ago... I have approx 2000 miles on the new tranny and the car is as fast as it was, the power is still there too.
I actually think the car shifts faster and better in auto now compaired to before... Same in SS.
Old 01-22-2004, 02:43 PM
Mr. Crimson's Avatar
I just brought my 2001 TL in at 49K miles because the tranny started "catching" between gears, (first time it did it, I thought I lost a wheel!). They are replacing it currently, and I'll try to ascertain what difference there is in the performance if any and report back.
Hoping to get it back by the first of the week. The Jetta they put me up in isn't bad, but I sure miss the power of the TL!
More Later-
Crim
mada51589
05-03-2022 08:54 PM
csmeance
09-10-2018 09:15 AM
Skirmich
09-15-2015 06:41 PM
jfman55
09-05-2015 02:55 PM
asahrts
09-04-2015 05:55 PM
Quick Reply: TRANS Replace, HELP NEEDED
