Tranny Swap Question!!
I was wondering since the 2nd gen TL's have so many problems with the transmission, would the 3rd gen TL tranny fit? I figured since they haven't had any problems....yet and engine is very similar, might be a direct swap. I don't want to be in that tranny replacement game everyone's been forced to play.
Any ideas anyone?
Any ideas anyone?
I'd rather be driving:
Nice idea. I'm wondering if it'll bolt up properly and if there might be an issue with the wiring/engine management computer? Just some things to consider.
318whp/289wtq @ 6psi
I believe the 04's had a problem but don't know what it was. Instead of paying 5000 for a new 04-06 transmission why not just throw one of those Dr. Evil transmissions on the car. I don't know if they cost 5k, just said that in general.
Just a thought.
Just a thought.
Just a thought.
Just a thought.
Acura OEM Parts
I'm not getting one but where did it say it didn't solve the problem. It's my understanding that they won't provide what their "secret" is. I mean truelly not a bunch of 5 speed autos were done but to my knowledge none of the transmissions have "deceased" that they did rebuild(mainly referring to the 4 speed accord/cl transmissions)
https://acurazine.com/forums/showthr...highlight=evil
The 4 speed tranny's never had a problem to begin with. The Dr. Evil version is basically for the tranny to handle more power. The TL tranny's problem is the clutchpacks. Unless the redisigned the tranny, its always going to have that problem., just later down the road.
If the 3rd gen tranny mounts to the 2nd gen and doesn't have that clutchpack problem, It'll be easier to find one from a junk yard and be cheaper.
Originally Posted by Type_S
In this thread it talks all about it:
Man ...I know about the problem with the clutchpacks. I'm not new to the website. Why does it matter if the transmission is built to hold power? If that's the case that means it can hold stock power also. Again, Dr.evil hasn't and probably won't disclose everything that he does to the transmissions so who knows if he changes the clutchpacks nor I care. I was making a suggestion. I won't waste money on an replacement from acura or dr.evil for that matter. Enjoy the automatic transmission and good luck in your quest for swapping these transmissions.
Again, Good luck.
2400 Watts in a TL...Why?
1 Post
"Hi I'm the ECU from your 2nd GenTL... Where did this F*C%ing tranny come from? How am I supposed to talk to it?"
If you wanted to swap the 3rd gen tranny onto the 2nd gen you would be opening a can of worms you don't want to..
First comes the 3rd gen ECU to allow the 3rd gen tranny to talk to the car, then the ECU can't communicate with the engine, so the next logical thing is to see if the 3rd gen tranny and engine will fit into the 2nd gen TL... and while you are going through that much changes you might as well add the 6MT tranny and the 3rd gen engine aswell.. then you'll have many more issues, like the ECU communicating with the dash cluster, ABS, VSA, etc.
The best options are a CL 6mt tranny into a 2nd gen TL (ala Fsttyms1), or a Dr Evil tranny.. the reliability is there for other tranny models, I 'm sure they would back up anything they would send you.. ifit were to fail they most likely would step up and help you with teh replacement/fixing.... Hell they would want to know for furure design purposes..
The problem for the 3rd gen tranny on our cars is the ECU controling. The ECU on the 3rd gen had drive by wire control and controls alot more of the engine tranny functions. The tranny should bolt right up. It uses the same block design. I think it would be a extreme pain to get the wiring to function properly trying to use it(but then again who knows till someone is willing to try)
02tljj
10-12-2015 10:39 AM
Skirmich
09-15-2015 06:41 PM
