tranny question, yea another one
havs anyone tried the 04+, 3-solenoid trannies on the 02-03 cars? i found a beauty of an 03 with tcc codes, and would rather just swap a newer trans off an 04+ tl or rl....im going on the idea that all j-series bellhousings will bolt up, if i am wrong, please set me straight
thanks
thanks
thanks, but neither of these answer my question...i want to keep the type s motor thats in the car now, just want to know if there is any ecu problem with using the newer transmissions(autos)
thanks
thanks
I got the Shifts
you must use the 2nd generation transmission.
the only trannies that ar einterchangeable are the manual transmissions. i was recommending doing a manual swap with the richie V6 harness. the two threads above will give you more information.
or you can stick to the auto-tragics.
search is your friend
Pham Alvan
03-16-2016 09:17 AM
navtool.com
31
11-16-2015 08:30 PM
navtool.com
09-25-2015 05:15 PM
