tranny fluid change,
Old 05-19-2009 | 02:09 PM
  #81
tlzib's Avatar
Originally Posted by CJITTY
^^Oh heck naw...who told you that mess
Well tell that to Acura cause when i had my trans warranty they always say your trans might be shifting a little hard due low tranny fluid and to top off if and when its needed, and that is the something iv been told at 3 different Acura dealers. Im on my 3rd tranny and seems to be fine knock on wood and it does shift a little rough due to low tranny fluid. I have 55k miles on this one and im not risking it.
Old 05-19-2009 | 03:15 PM
  #82
niju321's Avatar
which is better....3x1 every 7500 or 3x3 +1 (the 12qt method described earlier) every 20k? i put a lot of city mileage on the car.
Old 05-28-2009 | 11:33 AM
  #83
StonedCL's Avatar
B A N N E D
From: The grande.. Riverdale NJ.. Hopefully moving to skyline village in Lincoln park NJ..yes dirty jersey
I belive 3 x 1 every 15-20k miles and you will be fine..
I did a 3 x 1 at the dlr when new tranny had 30k on it and then I did a 3 x 2 (6 quarts ) with a friend of mine that has a 04 TL when my tranny had 60k on it and its shifting fine. Im gonna start doing 3 x 1 every 15 k miles now so at 75 K i will do my next tranny fluid 3 x 1!
Old 06-22-2009 | 08:57 PM
  #84
1st timer's Avatar
UB6IB9
Originally Posted by 01tl4tl
do a 3x3 which is actually 12 qts if done `per the book`-not 9, you are supposed to drain and refill it 3 times and then a final fill- that would really make sure the old stuff is cleaned out of the tubes and piping and TQ
read the owner manual and see if you agree with my interpretation of it
If you drain 3 qts and fill 3 qts 3 times,this makes 9 qts that you'll have to use to refill.I don't see where you get the 12 qts from.
Old 06-22-2009 | 10:31 PM
  #85
StonedCL's Avatar
B A N N E D
I don't either there is like 7-8 quarts of fluid in our tranny and 3x3=9..
I had this car since 2000 and had 3 tranny failures so i have some expience w/these trannies so like i said b4 im gonna get on a 3x1 or even 3x2 every 15-20k miles ..and im gonna change the 3rd and 4th gear switches.
Part #12 and #13 I read a tread on it here and asked my tech buddy from Acura and he said its a GREAT idea to change those out every 50-100k cuz it monitors the 3rd and 4th gear clutch packs or summtin..He explained it but he got too technical!
Old 06-22-2009 | 11:44 PM
  #86
bruistopher's Avatar
I'm in a situation like this. I'm thinking and coming to a conclusion, since I don't know my history on this car. Then I will just do the 3x1 change on my Acura for safety reasons.
mada51589
05-03-2022 09:54 PM
Yikes
05-03-2021 05:29 PM
ghuns
09-16-2015 05:26 PM
Aleax
09-11-2015 12:31 PM
HeloDown
09-08-2015 07:51 PM
Quick Reply: tranny fluid change,
