traction control light an abs light
Old 01-27-2003, 05:25 PM
winkly2000's Avatar
it was 10 degree in ct. today my car was wet from car wash when i went home tonight one of my wheels was frozen it dragged for about 10 feet than it poped an was ok,iam sure it was frozen now my abs light an traction contril light stay on what can i do to reset them? car goes fine
Old 01-27-2003, 08:13 PM
a locked wheel while driving will definately fock up your TCS and ABS. TCS and ABS compares the movement of all four wheels to determine whether or not TCS or ABS should be activated.
check it with your dealer asap.
joe
Old 01-28-2003, 10:54 AM
Greg D's Avatar
Disconnect the battery for a little while and then re connect it. There are wheels speed sensors on each wheel that tell the computer the MPH. If the computer senses one wheel not turning at the same speed, it can throw a code, and cause the light to come on. If disconnecting the battery doesnt cure it, bring it to the dealer. Something most likely broke. make sure you have your radio/nav codes after disconnecting the battery!
Old 01-28-2003, 06:57 PM
'99 Acura 3.2TL
@cUr@-TL's Avatar
id say BEFORE disconnecting the battery :p
@cUr@-TL
Old 01-28-2003, 07:32 PM
'Big Daddy Diggler'
bigman's Avatar
i'd say go to the dealer and make sure you didnt screw anything up. Your tranny may have been severely stressed
Old 01-29-2003, 09:52 AM
Greg D's Avatar
@cUr@-TL
Thats what I meant
mada51589
05-03-2022 08:54 PM
fifer16
1G RL (1996-2004)
10-16-2015 08:54 AM
Bahamanurse1
09-10-2015 10:05 PM
Charlespsu
09-02-2015 09:54 AM
Quick Reply: traction control light an abs light
