torx bit for headlights
i am planning on having my lights cleared ... thought i heard someone mention before that you needed a torx bit to remove the lights. I cant find the thread anymore but does anyone know what size I need? Thx.
T20 Security Bit aka Torx Bit. Basically it is just a regular T20 Torx bit with the hole in the center. I picked it up from a local hardware store for like a dollar or two.
So a plain T20 will not work? The actual screw has the pin sticking out the middle?
2400 Watts in a TL...Why?
1 Post
Originally Posted by thsiao
Can I remove the headlights with just regular screwdrivers?
Happy with my STi!
Originally Posted by ResidualFreedom
yes you can you just can't open the headlights ( to clear them or change the HID bulb)
Basically, you need the remove the cover to remove the bulb. How ever you want to do it. Remove the headlight THEN remove these items, it'll be a lot easier. And when you reinstall, put all the stuff back on first THEN the headlight.
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
AmplifiedDetails
09-24-2015 02:55 PM
