Torque spec for EGR Valve
Old May 16, 2011 | 07:23 PM
sbuswell's Avatar
I need 2 more gears
anyone know the proper torque spec for the two egr valve nuts? I can't find it anywherre, even in the service manual all 2187 pages of it.
Old May 17, 2011 | 12:06 AM
xtremex626's Avatar
Regional Coordinator (SoCal)
i just did it manually.. but in the correct order the DIY suggested. however much pressure you put into one bolt, you want to put to the others. make sure they're real tight though. as for the intake manifold cover, those don't need to be real tight, just tight enough, otherwise you will hear air hissing out of them. everything worked as should after
Old May 17, 2011 | 05:56 AM
Skirmich's Avatar
Its for an Accord 3.0 V6 but it must be the same (+ or -) for our Engines since they are made from the Same Materials.
16. Install the new EGR valve with a new gasket.
Torque the mounting nuts to 22 N•m (16 lb-ft).
Reconnect the 6P connector.
Taken from: http://www.honda-tech.com/showthread.php?t=2184564
Old May 17, 2011 | 07:52 AM
hANDYcaptd's Avatar
It's the Halladay season!
EGR valve, not intake manifold...
Old May 17, 2011 | 10:04 PM
sbuswell's Avatar
I need 2 more gears
16 ft-lb is what I was looking for and yes the EGV valve itself not the IM. IM is 16-18 ft lbs also.
fifer16
1G RL (1996-2004)
Nov 22, 2024 07:07 PM
Mike734
Dec 10, 2021 01:25 PM
08KBP_VA
Oct 22, 2019 01:55 PM
shawnafoxx
1G RL (1996-2004)
Sep 28, 2015 12:33 PM
prbori
Sep 27, 2015 01:37 AM
