TLS is revving up and down, Help
I have an '03 TL-S with about 12K miles. I'm in NY and it's very wet here in the last two days. Anyway, I came home from work tonight and started up my car. Everything was fine, I drove it a few blocks, then parked it and now when i had it in park, it revs from idle to about 2500 RPM and then back down continuisly. If I hit the brake, I hear a clicking noise. it's so wierd. Any ideas what can be causing it? I have a remote starter and alarm, but I don't think this is causing it. Donny
it happened to me once when i just started up the car in a cold morning. i then shut off the engine for a minute & no problems afterwards. if it continuously happen, a trip to the dealer is a must.
It happened to me, about two months after I bought the car. I called the dealer and brought it in. They kept it over night and told me that the computer had had a glitch in it. They "re-programmed" the fuel injection computer and it was fine after that. I've had it for about two years now and it has never done that again.
Good luck. I'd call the dealer and have them fix it.
Have you modded your car recently? There's been grounding issues w/ improper mod installations, which causes the cruise control to malfunction. Look into it.
Search on www.acura-cl.com too for more info.
SidhuSaaB
05-30-2020 12:40 AM
Pham Alvan
03-16-2016 09:17 AM
