TLS getting slow?
Old Oct 24, 2003 | 02:45 AM
ColdFusionTL's Avatar
TLS getting slow?
What's wrong with my car...it is getting really slow. I thought it was just in my head but even when my dad and brother drove it, they noticed it was lacking in power. The RPMS seem to be going up slower and overall response is starting to suck. The car feels slower than when it was stock. And another thing, my CAI isnt as loud as it usually is. It doesnt scream as loud as it used to. Even at night in the cold weather, the extra kick the car usually gets isnt there. I know its not just my imagination because all my friends noticed it too. Could there be anything wrong with my car? If any of you can give your insight on this, that would be great.
Old Oct 24, 2003 | 06:07 AM
yield2s's Avatar
Ya it sounds like the 2nd stage air intake butterfly is not activating. It should open at about 4200 rpms.
Old Oct 24, 2003 | 09:59 AM
bigman's Avatar
'Big Daddy Diggler'
yup, get that actuator checked out
Old Oct 24, 2003 | 04:26 PM
the actuator huh? I'm bringing my car to the dealer on monday for other problems..what should i say to the service guy regarding the loss in power and the actuator?
Old Oct 24, 2003 | 04:28 PM
Twenty03 Type-S's Avatar
What dealership (So Cal)?
Old Oct 24, 2003 | 04:42 PM
I take mine to Keyes Acura
Old Oct 24, 2003 | 04:53 PM
sc354's Avatar
well here's the problem you may run into. If it has anything to do with loss of power, the general answer you should expect is "The problem is not with the car, it's with your CAI". My guess is they will blame it on something like that. And on top of which, they don't have to prove anything. The fact that the Air intake system has been tampered with, is good enough grounds to deny you of the proper service. I would take it too a garage and have them look into the actuator problem.
good luck.
Old Oct 24, 2003 | 06:15 PM
Chemmech's Avatar
It's probably your oxygen sensor, when that goes bad milage and performance go out the window. However you cars almost brand new, Check that actuator thing.
Old Oct 24, 2003 | 07:08 PM
fsttyms1's Avatar
put the factory air box in if the dealer is going to probably make a stink about it, but i would bring it in to have them check it out
Old Oct 24, 2003 | 08:22 PM
Try reset the ECU first to see whether it make a difference.
Old Oct 25, 2003 | 12:38 AM
ferizzo's Avatar
still a Masshole
Check your tire pressure. Like a donkey I've been driving around with my tires at 23-26 psi the last few weeks and the car felt sluggish. I went to the track tonight and found out afterwards. I upped the tire pressure to 34 psi and sure enough the car feels stronger! Wish I knew before I ran!
Pham Alvan
Mar 16, 2016 09:17 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
steve
Sep 30, 2015 09:23 PM
hashbrown
Sep 29, 2015 12:13 PM
Acura604
Sep 28, 2015 12:24 PM
