tls fog lights
Check the manual... it gives you step by step directions.....
As a heads up... there is a 10mm nut under the lights. You need a long ratchet to be able to reach it b/c you have to go through a hole in the bumper. I removed both to change my bulbs and it took about 10 min.....
for the passenger side, i figure out that it's much easier of just unplug those two plastic screws underneath the car so as to remove the plastic cover. it's way better than what the manual says.
there's two ways to do it...alot of us find the method proposed by the manual requires more time and is more difficult...
it's much easier to do it from underneath...pop the plastic screw and stick you hands in there...it takes like a minute on each side ...
InFaMouSLink
10-27-2015 06:51 PM
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
